starter won't engage
Old Jul 11, 2006 | 07:55 PM
Green Streak's Avatar
Green Streak
I just swapped a 351M into my 78 F250 4x4 4 speed manual. I used a bell housing, clutch and flywheel off a 1981 F350 but didn't get the starter that goes with it. I have tried different starters 78 to 84 but cannot seem to get one to fit right. When I bolt them into place I can't turn the motor (using a socket on the crankbolt). What have I done wrong here, should I try shimming the starter out further from the bell?
Thanks in advance,
Greg
Old Jul 12, 2006 | 10:17 AM
Kemicalburns's Avatar
Kemicalburns
sounds like you may have the wrong clutch setup or your flywheel bolts are to long. what motor was in the 78 prior?
Old Jul 12, 2006 | 10:52 AM
Green Streak
It had a 300-6, I am putting in a 76 351m. I have the starter shimmed about 1/8" and it is free to turn the engine. I am charging the battery now and see what happens.
Thanks for the reply Kem...
Old Jul 12, 2006 | 01:04 PM
Kemicalburns
no problem, im glad you got it figured out.
Old Jul 12, 2006 | 05:44 PM
Green Streak
Opps .Just thought I had it figured out. Starter and solenoid both work fine BUT it is still not turning the motor, just clicks. I think I had better pull the motor back out and check my clutch and flywheel installation ( I still have the front off the truck so its not as big a deal)
Old Jul 13, 2006 | 09:07 AM
Kemicalburns
yea if you cant turn the motor over with a breaker bar up front then something is for sure binding up. I used flywheel bolts that were to long and they kept the motor from moving.
did the motor move freely before you bolted up to the tranny?
Old Jul 13, 2006 | 10:37 AM
Mike G's Avatar
Mike G
Can you turn the motor over by hand when the starter is not in or in the bellhousing? Is the trans in neutral when you are trying to turn the motor by hand? If the starter is specific for a M motor, then you should not have any problems. It is a process of elimination, take your time and trace backward.
--Mike
Old Jul 13, 2006 | 11:11 AM
1975Ford's Avatar
1975Ford
Something to check.
Did you install the flat spacer which goes between the engine and transmission?
Did you install the correct pilot bearing?
Could be the clutch disk was installed backwards?
Old Jul 14, 2006 | 12:28 AM
Green Streak
I got it working. I put some grease on the nose cone and found that the flywheel was rubbing against the snout just above the gear opening. I tried an automatic transmission starter and it works great. Thanks for the time you guys spent on this problem, its is greatly appreciated
Greg
AZRRC
Jan 21, 2014 12:11 PM
78250crewcab4x4
Jan 22, 2010 10:28 AM
gcfisher75
Nov 23, 2006 11:54 PM
toolz_not_toyz
Jul 26, 2004 09:29 AM
toolz_not_toyz
Jul 22, 2004 02:58 PM
