96 Clubwagon XLT engine?
Old Jul 11, 2006 | 03:10 PM
bgothmann's Avatar
bgothmann
Question 96 Clubwagon XLT engine?
I'm about to do some work on my church's 96 15 Pass Clubwagon XLT so we can take it to Colorado. What engine does it most likely have? (it's the original) I'm sure from looking at it that it's not a 460 but I'm not enough of a Ford guy to know what it is, or even what it could be. If it's a V8 but not a 460 is the only other possibility a 351?
Also, where is the fuel pump inertia switch reset button?
Thirdly, are there any problem areas in 96s that I should be looking at?
Thanks for your help.
BGothmann
Old Jul 12, 2006 | 11:32 AM
Clubwagon's Avatar
Clubwagon
Check the emissions sticker under the hood. It will tell you what engine it has. I think the standard engine in a '96 15 passenger will be a 351 but it could also be a 6.8 liter V10. '96 was the first year for the V10 which replaced the 460.
Steve
'95 Clubwagon XLT
Old Jul 12, 2006 | 01:05 PM
bgothmann's Avatar
bgothmann
Smile 96 Clubwagon XLT engine, what have I got?
The emissions sticker is gone. It's not a V10. What I don't know is if it could possibly be a 5.0L If the possibilities are just V10, 5.8L (351), and 6 cyl, then I know what I've got. Is there an easy way to tell the difference between the 5.0 and the 5.8?
BGothmann
Old Jul 12, 2006 | 01:12 PM
subford's Avatar
subford
Behind RH (passenger) cowl (kick) panel.
I do not find a V10 listed in the 1996 Econoline Service Manual.
It does show a 460, 351, 302 and 300 gas engines.
Old Jul 12, 2006 | 04:28 PM
fordfan2006's Avatar
fordfan2006
Try entering the VIN on the following web page:
https://www.fleet.ford.com/maintenan...ls/default.asp
That should show you what engine was installed in the van. -FF2006
Old Jul 12, 2006 | 04:43 PM
bgothmann's Avatar
bgothmann
Smile RE:Clubwagon XLT engine?
Thanks for the link. I'll enter the VIN and see what happens.
Thanks for the location of the reset switch too.
BGothmann
Old Jul 12, 2006 | 06:21 PM
pfogle's Avatar
pfogle
Look at the VIN if the 8th digit is an "H" then it's a 351, "N" is a 302, but it's a one ton (E350) so that wasn't an option in '96.
Old Jul 14, 2006 | 01:23 AM
bgothmann's Avatar
bgothmann
OK, so I'm even less of a Ford guy than I thought. It IS a 460. Thanks everyone for all of your help.
BGothmann
