General Diesel Discussion
body lift for deisel?
Old Jul 11, 2006 | 01:34 PM
hilljackusmc's Avatar
hilljackusmc
any body know of any manafacturer that makes a body lift for a 87-91 f250 deisel. or if its even possible to put a body lift on a deisel. thanks!
Old Jul 11, 2006 | 07:44 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
A body lift is possible for any vehicle that's not a Unibody design. Yes it is possible and fairly common. Some people do it to allow for more room for bigger turbo exhaust pipes (You don't have a turbo) . Some do it for appearance, some for tire clearance. Just bear in mind that any component that connects to the body on one end and the frame on the other end will need to be lenghtened. Body lifts are basically spacers that go between the frame and the body. The higher you go, the more involved it gets. For example your motor will not move up, nor will your cooling fan, but your fan shroud will. Go too far and the fan will hit the bottom of the shroud if you don't plan for it, your steering column, brake lines, throttle linkage, and shift linkage are just some of many things that will be affected.
IMO a mild body lift is the most basic lift kit, and probably the cheapest way to lift.
Look at the top of your screen and check out our sponsors, many of them have what you need.
Old Aug 6, 2006 | 10:48 PM
wolfe1104's Avatar
wolfe1104
Im not sure your reasons for wanting a body lift, but from my experience body lifts suck. they may be a cheap way of getting a few extra inches, but they mess up so much crap. I didnt have a diesel, but it was a similar body style, and i really regreted doing the 2in body. one of the main concerns i had was the body roll. but that was the least of the problems i had.
Old Aug 7, 2006 | 10:25 AM
hilljackusmc
thanks for the info, i have a 4 inch suspension lift but my 35s rub so i was trying to figure out away to get just a few more inches with out moving up to a 6 inch suspenions lift. i put a 3inch body on my 98 chevy and never had anyproblems out of it. i guess ill just have to cut the old ford to make it work thanks for the advice.
Old Aug 8, 2006 | 07:11 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
Where are the tires rubbing? you may be able to change the backspacing of the wheels, or some other ways may be available to help you clear the tires.
Old Dec 4, 2006 | 01:47 PM
hilljackusmc
has anybody hear done a body lift on the old diesels.
old blue beast
Jan 18, 2013 06:59 PM
hilljackusmc
Jul 11, 2006 08:09 PM
jmnt919
1983 - 2012 Ranger & B-Series
Mar 15, 2005 11:01 PM
John Luther
Jun 22, 2004 06:21 PM
