Squeaking clutch?
Old Jul 15, 2006 | 01:43 AM
RangerPilot's Avatar
RangerPilot
It's not nearly as difficult as it sounds. The PITA part is gettin' the tranny out. Gotta unhook everything, get it onto a jack of some sort and out from under the truck.
Once you do that, the rest is easy. Just a matter of replacing parts. Then reinstall the tranny and bleed the clutch (will require 3 people, PITA). And off you go.
And you can get clutch kits on eBay for MUCH less than Summit. That's what I'll be using before I leave for college.
RP
Zach
Old Jul 15, 2006 | 02:00 AM
CrazySpyder69's Avatar
CrazySpyder69
RP
Zach
Lol, Wanna hook up and have a tranny/clutch rebuild party?
Old Jul 15, 2006 | 09:27 AM
Pablo-UA's Avatar
Pablo-UA
Ranger is small truck. It is easy to remove tranny. You can do it yourself!
Old Jul 15, 2006 | 10:36 AM
natebaker's Avatar
natebaker
How much are we looking at for the M5OD? I'm having the squeaking as I let out the clutch, no problems getting it into gear yet, but I'd replace the whole thing. I'll prolly do it in a month or so as my two brothers will be in Utah to help.
(I meant how much for clutch/throwout bearing/pressure plate/flywheel resurfacing)
Old Jul 15, 2006 | 11:14 AM
RangerPilot
As I said, you can find clutch kits out there for less than $200 bucks.
http://cgi.ebay.com/ebaymotors/93-97...05418801QQrdZ1
Flywheel resurfacing I imagine can't be much, though I'm not sure on that one, never had it done.
Crazy I'd be more than happy to but I wasn't planning on doing mine for a while. Yours need to be done now, as in ASAP?
RP
Zach
Old Jul 15, 2006 | 10:32 PM
CrazySpyder69
Flywheel resurfacing Crazy I'd be more than happy to but I wasn't planning on doing mine for a while. Yours need to be done now, as in ASAP?
RP
Zach
No, not really. But I would like to do it soon so I dont mess any other things up causing me more problems in the future. The way I look at is, spend a little money now to save alot in the future.
Wow 115 + shipping isnt bad at all. The one I found was 250$.
Old Jul 15, 2006 | 10:35 PM
RangerPilot
What do you guys think about Boss clutches? That's the one in the link I showed...good/bad? I know stuff listed on eBay can go either way, and I'm wary of anything listed as "Premium series".
RP
Zach
Old Jul 15, 2006 | 11:03 PM
CrazySpyder69
Well I was on my way home tonight from work and as I would slow down to a light my truck would drop rpm's like crazy. It would go under 500 rpm's. Seemed like 300 or less rpm's.
Now I dont know if this has any thing to do with the above problem, but I dont know if im freaking out or what but could this be caused by from what the mechanic was talking about it seems like the throwout bearing going out is causing the clutch plate to not fully engage. Now dont start flaming me for this because he said alot and I was confused half of the time and I might have mixed up some words.
But let me know what you think.
Old Jul 15, 2006 | 11:54 PM
RangerPilot
If you put it in neutral and coast to a stop does it do it? If not then yep, the clutch and therefore the tranny, drivetrain, etc. is dragging the engine down.
RP
Zach
Old Jul 16, 2006 | 01:27 AM
CrazySpyder69
RP
Zach
Ahhhh, good thinking. I will try that tomorrow and report back my findings.
But was I right on my last post?
Old Jul 16, 2006 | 12:07 PM
RangerPilot
I'd believe so. Typically clutch dragging is either one of the cylinders going out or the throwout bearing.
I'd bet first on the slave going, as it's just not that reliable, but since you see no leak around the tranny, it's gonna be the bearing.
As your clutch drags at stoplights when you're on it, it's going to be burning off fast. The engine is turning at 500 RPMs, the tranny innards are turning at 0 RPMs, and your clutch is stuck burning off to make up the difference. Don't be surpised if when you get in there it's pretty worn out.
While you're in the tranny, you definetly should replace the clutch, throwout, pressure plate, have the flywheel resurfaced, and I would replace the slave. It's just to unreliable to leave the stock one in there then know I might be back in there in a month 'cause it crapped out.
RP
Zach
Old Jul 16, 2006 | 03:04 PM
CrazySpyder69
RP
Zach
Yeah, cool. If I ever change it I will go ahead and go the whole 9 yards and change everything.
Why resurface the flywheel? What does that do?
Coachhick
Feb 19, 2016 02:44 PM
HighRiskJob
1997 - 2003 F150
Sep 16, 2014 09:22 AM
AkF250HD
Aug 7, 2013 06:31 PM
mfp4073
16
Nov 30, 2012 07:22 PM
rbsample
Jun 6, 2011 10:21 PM
