Gears?
Old Jul 12, 2006 | 09:56 PM
1979FordF-250's Avatar
1979FordF-250
Talking
I just looked up the specs on my tranny and it said that I have a 3.90:1 1st gear. I was wondering if that is a respectible low or is is a ratio you would find is a mustang or other car.
Old Jul 13, 2006 | 06:35 AM
phatpony's Avatar
phatpony
Dude, you drive a truck! Your tranny is designed for a truck. It has a lower first than a car. I don't understand this whole thing about trying to compare the performance of your basically stock truck to a Mustang. I'm not trying to be a d1ck, but come on, compare apple to apples.
Now, I just traded my 03 Mustang GT for my 04 F-150 STX. Same 4.6L engine. I had 4.10 gears in the stang, this truck, 3.55. The stang came with 3.27 gears stock. In it's stock form, the Mustang would murder any 4.6L, stock F150, period.
Old Jul 13, 2006 | 04:51 PM
1979FordF-250
Cool
WHAT THE HE!! ARE YOU TALKING ABOUT? You must have read the wrong thread. Let me interperate; I was talking about comparing the 1st gear ratios thats it!! No rearend ratios or motors to a mustang. Nobody will catch me trying to chirp gears against a stang! I am well aware its a truck, I noticed that from the 6.5ft. bed hanging off the back. I know they aren't built the same.
Old Jul 14, 2006 | 06:06 AM
phatpony's Avatar
phatpony
Yep, I knew I would come across as a d1ck, didn't mean to. Sorry.
Old Jul 16, 2006 | 10:37 PM
1979FordF-250
Yeah I'm sorry about the burst. I got fired up.
Old Jul 17, 2006 | 06:06 AM
phatpony's Avatar
phatpony
It's all good bro.
Old Jul 17, 2006 | 12:01 PM
exiled's Avatar
exiled
1979fordf250, i but stiffer control arms on my mustangs to control axle wrap. i found that to be the cheapest way of going. you can prolly find a way of making this work on your truck. no the mustangs control wont but maybe something made at home. you need some downward thrust over the axles when you take off. i assume you already know this. as to your question about 1st gear i could'nt find the gears in my mustangs repair manua so i cant answer that.l
Old Jul 17, 2006 | 05:58 PM
1979FordF-250
Talking
Thanks for the idea, but I was thinking about ladder bars, and I was hoping that if I lowered the back end that it might come with stiffer leaf springs that won't wrap up on me.
Old Jul 18, 2006 | 12:01 PM
exiled's Avatar
exiled
that may work. if you get it hooked up let us know what the out come is.
Old Jul 18, 2006 | 08:11 PM
Panzerbrumbar's Avatar
Panzerbrumbar
Originally Posted by Cavtrooper06
I have a 04 Lariat Screw 5.4 and I could not find my code in here. It says 26 on the door tag. I was wondering if anyone could help me. The only place I could find the number was in the 3/4 ton code. From what I can tell I think I have a 3.55 LS but would be nice to know for sure. Any help would be great
Old Jul 18, 2006 | 09:00 PM
Cavtrooper06's Avatar
Cavtrooper06
You could check on the rear diff. There is a metal tag attached to a bolt and the gearing is imprinted on the metal tag.
Old Jul 18, 2006 | 09:03 PM
1979FordF-250
Talking
He's right I found the two tags on the differencial the other day. One says the gears that you have and what differencial size. The other says the date it was manufactured or something like that.
Old Jul 18, 2006 | 09:11 PM
  #28
Panzerbrumbar
I did know about the tags on the axle but I was all cleaned up after being dirty all day and did not feel like crawling under the pickup so I was being lazy and hoping someone had an answer the lazy way. Thanks for your help though, I will just have to crawl under there after work tomorow.
Old Jul 19, 2006 | 06:13 AM
  #29
phatpony's Avatar
phatpony
"Usually" if the axle code has a letter in it, it is LS. Your code is all numbers, so I don't think yours is LS. I'll work on decoding the number if I can get time.
Old Jul 20, 2006 | 08:55 PM
  #30
Panzerbrumbar
Well I crawled under and could not get a ratio size but I found a tag saying
V956F on it. And I am pretty sure I have the 3.55 due to my rpm on the interstate and I checked on dry pavement and burnt a layer off of my new Bridgestones and there were two marks from some expensive rubber. Oh well love the pickup regardless and I get great mpg. So I am better then fine and if you are right you will agree.
