Air Bag light
Old Jul 10, 2006 | 11:23 AM
pablocruz69's Avatar
pablocruz69
Air Bag light
I have a 97 expy 4.6l 4x4. The air bag light started flashing. It flashes two times then five times, it does this two or three times and then it stays on. WHat does this mean?
Old Jul 12, 2006 | 09:21 AM
KHaga's Avatar
KHaga
I had this happen (air bag sensor can't find the air bag in the steering wheel) in my '00 Expy EB, and it was eventually followed by a loss of my horn and my cruise control. Basically, the clock spring wiring harness that connects these three electrical components from the steering wheel to the steering column gets worn out.
I had mine replaced recently at the Ford dealer and it cost about $230. Problem solved!
Old Jul 12, 2006 | 10:09 AM
pablocruz69
I'll have it checked. Thanks for the reply.
Old Jul 12, 2006 | 01:38 PM
projectSHO89's Avatar
projectSHO89
Recheck your flash pattern at key-on. The service manual does not have anything for a LFC (Lamp Fault Code) 25.
There are a number of LFCs that may be related to the clockspring. However, don't screw with it until you have an accurate assesment of what your fault is. There are several other things that can cause the AIRBAG light to flash. Unless someone else had the exact same pattern, it may not be relevent.
Steve
Old Jul 12, 2006 | 04:11 PM
pablocruz69
I am going to get in to the dealership and have them look at it. Thanks for the advise.
Old Apr 14, 2007 | 02:05 PM
clydesdale558's Avatar
clydesdale558
Unhappy my airbag light flashes 5 then 2 then stays on
does anyone know what this code could be?? your help is greatly appreciated
Old Apr 24, 2007 | 07:18 PM
justinhardy's Avatar
justinhardy
mine just started it, too. 5 then 2, 5 then 2 (a few times), then steady on. where do i find a fault code list? thanks.
98 expy 4.6L 2wd with 254,000 miles :-)
Old Apr 24, 2007 | 07:21 PM
justinhardy
wait, found the answer:
It just indicates a low voltage situation had existed and now is at normal voltage. The code 52 will remain until cleared with scanner or a certain number of key cycles without fault. Autozone will reset for free...
shark1979
1983 - 2012 Ranger & B-Series
Oct 8, 2010 08:33 PM
Bob V
Feb 14, 2009 10:45 PM
whruppe
Aerostar
Jan 16, 2008 09:05 PM
BHOFFMAN
1978 - 1996 Big Bronco
Jan 27, 2004 02:23 PM
doc300
Jul 28, 2001 10:01 AM
