05 6.0 changing air filter??
Old Jul 9, 2006 | 04:53 PM
hobbit's Avatar
hobbit
I have heard that the air filter on the o5 6.0 is difficult to change. Any advice?
Old Jul 9, 2006 | 05:14 PM
hokie350lt1's Avatar
hokie350lt1
Welcome to the site Hobbit. Changing the Air filter isn't the easiest thing you'll ever do but you shouldn't have a problem gettin it done. You'll find some good info on it with diagrams in the Tech Folder.
Old Jul 9, 2006 | 05:25 PM
hobbit's Avatar
hobbit
Since I am a newvie- how do I get to the tech folder? Thanks
Old Jul 9, 2006 | 05:28 PM
Pittsburgh-05HD's Avatar
Pittsburgh-05HD
look at the post above this one
Old Jul 9, 2006 | 06:04 PM
Kentucky Skipper's Avatar
Kentucky Skipper
They had the same idiot engineering that air filter that engineered the bottom fuel filter. Changing that air filter isn't easy. The old 7.3's I could change with bare hands in about 3 minutes. This filter is different.
First unbuckle the 4 clips and go ahead and remove them because if you don't they are liable to fall off and end up trapped in the tanglement of wires and hoses on the engine or more likely fall down into the intake and have to be fished out.
The front is easiest to get loose, wiggle the thing till the plastic tabs underneath come loose. It may take some force.
Now, loosen the air filter, there are 4 studs in bottom and they'll pop out. That again will take force.
Then wiggle it loose from the rear tube.
Then you just got to reverse the process. A long screwdriver or 2 helps.
Skipper
Old Jul 9, 2006 | 06:25 PM
nomorecummins's Avatar
nomorecummins
Oh yeah, its not a typo when you see how much the air filters cost..... If im not mistaken, I saw them at Wallyworld for $60.00... Yes thats Sixty dollars....WTF....
Old Jul 10, 2006 | 06:19 AM
locked up's Avatar
locked up
Try this link
I used this and changed mine in 10 min.
http://www.forddoctorsdts.com/articl...icle-06-01.php
Old Jul 10, 2006 | 10:02 AM
kw5413's Avatar
kw5413
Here's the link to our own 6.0 Tech Folder
https://www.ford-trucks.com/forums/s...d.php?t=303583
And here's the Tech Folder Link to Changing of air filter, in detail:
http://home.austin.rr.com/sbv1/Proce...irFilterRR.htm
Coro's Avatar
Coro
Proceedure referred to by "locked up" is a lot easier than the old "bloody-knuckle" method.
Just a note that to "Disconnect the MAF or IAT sensor." you need to squeeze with a downward thumb pressure while pulling to separate. Also to "Remove the Filter Minder" just turn and pull and it will eventually come out.
Also do first remove the clips and set them aside as said by Skipper.
Old Jul 10, 2006 | 12:00 PM
gopedoligist's Avatar
gopedoligist
thanks alot locked up, not quite time to change yet but i was bored yesterday and spent about 20 minutes trying to figure it out.
keep it ford
Old Jul 13, 2006 | 03:01 PM
gbrault's Avatar
gbrault
It is kind of a bear to remove, just be patient and rock it back and forth - the tech folder was great help.
Old Jul 29, 2006 | 10:00 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
The filter will last 50,000 miles.... so a few minutes of work and a few cuss words is worth it to me!!! I use only the stock, blue synthetic media air filters and trust them 100%!!!!
Blue media = synthetic fiber media (stock filter) - Made by Donalson
White media = cellulose (paper) media - Made by DOnalson
The synthetic media is moisture/water resistent and will last longer... but it does cost more... but it is what comes with all 6.0L's off the assembly line!!!
Old Nov 4, 2006 | 08:59 AM
TheDuke's Avatar
TheDuke
Not so much, mine came with a white media filter
Old Nov 4, 2006 | 07:19 PM
Beachbumcook
Got Diesel?
Confused... what do you mean?
"...not so much... mine came with a white media filter?
Old Nov 5, 2006 | 10:54 AM
TheDuke's Avatar
TheDuke
My truck came stock from ford with a air filter with the white material...not blue.
