How fast…
Old Jul 10, 2006 | 12:08 PM
JCorbin's Avatar
JCorbin
9800 miles
Old Jul 10, 2006 | 12:26 PM
RangerPilot's Avatar
RangerPilot
At 9800 miles it should be broken in. Something's definetly up, it should have zero problem going right past 3K.
RP
Zach
Old Jul 10, 2006 | 12:52 PM
Alan D.'s Avatar
Alan D.
I agree, hit up the dealer. make them make it work right.
Old Jul 10, 2006 | 01:03 PM
monsterbaby's Avatar
monsterbaby
You guys are missing his point, it's not that the engine is lmited to 3000rpm, just limited to 3000 rpm in top gear, IE 92mph = 3000rpm in overdrive. There is nothing wrong with the motor, just the factory speed limiter working properly.
Old Jul 10, 2006 | 01:19 PM
Alan D.'s Avatar
Alan D.
oh yea, lol. i guess your right. missed that. yea if it's in o.d. then you shouldnt be able to go any faster than that because the speed governer would kick in and tell the computer not to let any more fuel into the engine. guess you dont have a problem, lol. unless you consider your speed governer a problem.
Old Jul 10, 2006 | 02:57 PM
Dave257's Avatar
Dave257
Originally Posted by Alan D.
wait you cant go above 3000 rpm? that not right, i can go to 5500.
ummm I thought you said you had replaced the chip and went 137...It sounds like you are saying you can go to 5500 with the stock chip...why else bring up that you can hit 5500 on a non stock chip??
As A side:
The cpu will limit the engine speed to 3000rpm in park and neutral, and limit the Truck speed to the low 90's on the newer trucks.
Dave
Old Jul 10, 2006 | 04:34 PM
RangerPilot
Umm no...3000 in OD is NOT the limiter speed. Well......maybe with 4.10s or the like. 3000 is nowhere near 92 or 97 in my truck.
What ratios are we talking here, and auto or manual?
RP
Zach
Old Jul 10, 2006 | 04:47 PM
Dave257's Avatar
Dave257
ummmm...I will repeat,
Dave
Old Jul 10, 2006 | 04:55 PM
Daniel2986's Avatar
Daniel2986
So let me get this right...so what we're saying is in order to make your truck go 92mph+ replace the stock chip?
Old Jul 10, 2006 | 04:58 PM
Dave257's Avatar
Dave257
Yep, New chip with the limiter bypassed
Dave
Old Jul 10, 2006 | 05:47 PM
blueranger99's Avatar
blueranger99
Just after I installed my air intake, I hit 105 mph with my ranger on a nice flat section of highway a few years ago just to try and see where it would max out at. It was still accelerating, but I got scared and backed off - it was feeling too light on the road - aerodynamics just aren't as good as most cars on the road. I haven't tried it again. I think my ranger would max out at about 110 or 115 - but I'm not going to try it .....
Old Jul 10, 2006 | 07:40 PM
91teenranger's Avatar
91teenranger
My little 1991 ranger will go 110 mph because of slight mods. then the limiter kills me.
Old Jul 11, 2006 | 06:53 AM
  #28
Alan D.'s Avatar
Alan D.
if you want to go fast in your rangers never level them.you'll be like an airplane. also when going fast, it's easier(for me) to control if you put the steering wheel at it's lowest posistion. and dont be jerky. i've watched alot of guys loose thier trucks to jerky moves. remember keep it smooth, thats why i put the steering wheel like that. also, try not to brake in the turns set yourself up before them. else you'll slide right out of them. i did that one. luckly it wasn't in a bad spot and didn't hit/role it.
Old Jul 11, 2006 | 08:06 AM
  #29
RangerPilot
Been there done that with people hitting the brakes in corners and sliding right off the side. Fun to be a passenger in, definetly wouldn't try it in my truck.
RP
Zach
Old Jul 11, 2006 | 08:17 PM
  #30
notstirred12's Avatar
notstirred12
Mine governs out in the vicinity of 95ish, but I can't nail down the actual speed. It was downhill with a tailwind at the time and the truck was fighting me pretty hard.
On a second note, does this hold true for all Fords (out of the factory). I doubt so for Cobra's and other high performance vechiles, but what about a plain-Jane Mustang? Really just curious.
