Brake light woes
Old Jul 9, 2006 | 10:54 AM
scamardo's Avatar
scamardo
Brake light woes
Hey truckers,
I got some wierd brake light issues going on. No brake lights, however got tailights with the headlights on. Got a left signal that burns but not the right. Not sure where to start troubleshooting on this. Bulbs are fine. Any idea's?
Old Jul 9, 2006 | 11:03 AM
jd_sylvia's Avatar
jd_sylvia
I would start with the turn signal switch in the steering colum that sounds like a problem I once had that was cured by installing a new switch.
Jon
Old Jul 9, 2006 | 11:04 AM
airharley's Avatar
airharley
I have to agree all the problems lead right back to the switch.
Old Jul 9, 2006 | 01:26 PM
Customcab's Avatar
Customcab
I would also resurface clean the ground wire to body molding on each tail light, those seem to build up corrision and even especially after you repainted the bed; you need to ensure a good ground to allow for a constant ground. To me not having brake likes sounds like a grounding problem. Additionally; I once was fighting with a lose fuse connection under the dash, but I lost turn signals and all during this troublesome time. You stated your left t/s works and parking lights but notthe brakes.
Mitch
Old Jul 9, 2006 | 06:42 PM
daveengelson's Avatar
daveengelson
Could be turn signal switch but rec going with Mitch's suggestion first. Clean ground contact points at each turn signal, front and rear, see if any improvement. Also, may try disconnecting the leads to the brake switch in engine compartment, with ign. on ground the leads and if they light up then switch could be bad. Then there is the flasher unit located under the dash. Bah, darn electrical problems. Surprising how poor ground effects circuits.
dave
Old Jul 9, 2006 | 06:45 PM
scamardo's Avatar
scamardo
Thanks fella's for the feedback. I was leaning that way as well on the switch, but didn't want to sink $60 on the part without getting some feedback.
Thanks again and will let you know the outcome.
Old Jul 9, 2006 | 08:41 PM
Putt's Avatar
Putt
Did anybody think to check the brake light switch and power?? Easy to test and easier/cheaper than the turn signal switch to replace. I would also clean and check the grounds at each light, a bad ground can cause some very strange problems.
Old Jul 9, 2006 | 08:53 PM
scamardo's Avatar
scamardo
Yep, that was the first thing I checked.
