Sponsored by: Real Truck
How Bad Is It
Old Jul 8, 2006 | 09:26 PM
dougger222's Avatar
dougger222
Find a beater to toss the gas/diesel mix into. A few years ago while working on a job a couple hours from home I brought a tank of diesel fuel and one of my guys accidentaly filled the 5.5 Honda air compressor with it. Half the tank was used when I ran down the ladder. I tossed the compressor upside down ran the diesel out of it and filled it with gas and it fired right up. The motor still runs but the pump failed a year or so after.
If it were my truck I'd drop the tank as previously mentioned and let it be a $84 lesson learned. One of my mechanic buddy's had to do the fuel tank empty job after being filled with gas and he charged around $150 to make the problem go away.
Old Jul 11, 2006 | 05:57 PM
herrfixit's Avatar
herrfixit
Drained it , cleaned it and runs good cheeper to drain than chance it
Thanks
Old Jul 11, 2006 | 06:18 PM
RocketScience's Avatar
RocketScience
You should be OK to just pump/siphon out the gas and replace with diesel.
Here's a good thread on this very debate:
LINK HERE
Old Jul 11, 2006 | 06:24 PM
carl~n~sa's Avatar
carl~n~sa
would definatley say drain it. might be a loss of 88$ but could save you thousands in the long run IF things go bad.
Old Jul 11, 2006 | 06:54 PM
SpringerPop's Avatar
SpringerPop
Originally Posted by herrfixit
Drained it , cleaned it and runs good cheeper to drain than chance it. Thanks
Price of that screw-up, $87.32.
Peace of mind: PRICELESS!
Pop
Old Jul 11, 2006 | 07:07 PM
FordGuy0131's Avatar
FordGuy0131
Info on gas in diesel engines
Based on Diesel Power magazine, it is not ideal to have gasoline in diesel engines, but as much as 30% of fuel can be gasoline. In your case you have too much, and you will need to siphon like the rest on the guys said. I accidentally added gasoline to my diesel tractor and had to siphon it out.
Good luck,
FordGuy0131
KDAVID1
Feb 16, 2015 05:55 AM
El Camino Man
Feb 25, 2013 05:49 PM
Alcoa
Feb 13, 2013 08:27 AM
12amracer
Aug 24, 2012 05:39 AM
hay is for horses
6.7L Power Stroke Diesel
Aug 14, 2012 01:23 PM
