Thanks for the concern, not yet due to other commitments and diversions. I have, however, found a source where I can get the swaged end cable fabricated, at least that's what they tell me they can do. I'll be seeing about that next week. I'll let you know if it works.
Ray, the hydraulic brake lock will hold all four wheels in the locked position regardless if your foot emergency brake works or not. The hyd. brake lock ties into the normal brake system, when you push the brake pedal down and flip the brake lock lever it automatically holds the line pressure in the normal brake system until you release the brake lock lever. They even make an electronically operated brake lock! Hope this clears up the function for you. Good luck. "bowties in the rearview mirror"
