2000-2001 5.4 triton
Old Jul 7, 2006 | 08:08 PM
CF-DRG's Avatar
CF-DRG
I'm looking into getting a new/used truck.. One's a 2000 f-250 SD 4X4 with a 5 speed standard and has 80,000 miles, and the other is a 2001 f-250 XL SD 4X4 with a 4 speed auto with 100,000 miles... Is there anything I should look for..? I've had my 84 diesel f-250 too long and am a little out of touch with the gas stuff.. Fuel economy is my biggest concern so the 5.4's in both of these seems to fit the bill... Or should I look into something else... Any suggestions??? I'm not towing anything big or hauling heavy loads anymore so that's why I have considered the smaller V8 gas models in my search...
Old Jul 7, 2006 | 08:30 PM
F350blueberry's Avatar
F350blueberry
I just bought an 06 5.4 f350. My choice was based on what i was going to use the truck for. I don't think it will get the mileage of your 84.In fact I wish I still had my 85' diesel it was a great truck. If you are driving long distances on a regular basis get a diesel if you are towing and hauling get a diesel. Another thing to keep in mind is that the v10 owners claim they get almost as good mileage as the v8 but with alot more HP.
Old Jul 7, 2006 | 11:10 PM
CF-DRG's Avatar
CF-DRG
I would consider another used diesel but they are another $5-6000.00 more than the gas models and are hard to find with less than 150,000 miles (everyone towing a fifth wheel across the country 10 times)... The way I looked at it is $5000.00 buys alot of gas, and I can't see saving that with the diesel over a 5-8 year span (that's how long I would probably keep the new truck) .. I guess I could consider the bigger V8's, I don't know about the V10!!! Is it a reliable engine? I should have posted this under the general questions,, but the 2 trucks I was looking at both have the 5.4.. so you might see this again in one of the other forums... thanks for the reply F350
Old Jul 8, 2006 | 01:00 PM
LxMan1's Avatar
LxMan1
5.4L is the biggest V8 gas engine that Ford makes now. The V10 is a 5.4L with 2 more cylinders.
Old Jul 8, 2006 | 01:37 PM
2000Ford2000's Avatar
2000Ford2000
A 2000-2001 5.4 is a V-8 isn't it? Mine is. Don't look for great gas mileage. I guess it depends on what you consider mpg. My 2000 E-150 5000 lb. van get's 15.5 tops. If I just bump my speed up to 60 mph on 55 mph roads, it drops 1-2 mpg. My mileage goes from 12.5 to 15.5.
I was disappointed at the mileage to say the least when I got it last year. I have an 89 E-150 with the 302 and it gets 18 mpg. I expected better out of the 2000. I found out since that after 98 or so, Ford put HO heads on all the 5.4's. Possibly that is why the lower mpg.
Old Jul 8, 2006 | 07:01 PM
LxMan1's Avatar
LxMan1
Yes the 5.4L is a V8 and the 6.8L is a V10. The PI heads shouldn't hurt mileage, they have improved intake ports that make them more efficient, which also makes more power. About 35 more than non- PI heads.
Old Jul 8, 2006 | 10:01 PM
CounterMaker's Avatar
CounterMaker
i have a 2006 f250 5.4 3.73 and i got 11.4 mpg when driving aggressive and 13.2 when driving like a grandma...im completley happy with it because i tow nothing and haul only counter tops...the 5.4 2v (2004 and before) and 3v (2005-present) are both reliable solid engines...
Old Jul 9, 2006 | 10:03 PM
2000Ford2000
LxMan1, I think my problem is I tend to use that 35 more HP more often than I should. I used to not think anything about it just a year ago, but with it costing over $100 now to fill my tank...
Old Jul 9, 2006 | 11:20 PM
LxMan1's Avatar
LxMan1
Yep, every time I feel the power, my wallet gets lighter. I try to drive easy, but with the Predator and Flowmaster exhaust, it's hard sometimes.
Vinford
Apr 13, 2014 06:12 AM
vtmudder95
Mar 7, 2011 07:29 AM
deano2
Jan 26, 2006 09:03 PM
HogTied
Oct 24, 2004 06:45 PM
Bogeyfree31
Nov 13, 2003 08:08 PM
