engine will sputer then die
Old Jul 4, 2006 | 04:03 PM
22lr10xxx's Avatar
22lr10xxx
2000 power stroke will run fine and just shut off, no code like it ran out of fuel. changed fuel filter because i checked most everything else. it will shut down at speed also, and has always restarted sometimes i have to cycle key a few times. any help befor i give in and take it to ford. i never let anyone work on my stuff
Old Jul 4, 2006 | 04:11 PM
PSNut's Avatar
PSNut
Sounds like you have a CPS going bad. Change it out and keep a spare. Common problem with these trucks.
Ford gets around $175 for the part. On E-bay you can do MUCH better;LINK
LINK to a picture of location and install instructions.
Nut
Old Jul 4, 2006 | 04:50 PM
kawika's Avatar
kawika
Ditto - CPS, mine did the same thing until it finally died...
Old Jul 4, 2006 | 05:23 PM
22lr10xxx's Avatar
22lr10xxx
yes thought that my be problem but tach works fine when it happens i picked one up for 151 bucks it is easy to change did it for outhers but everyone else that had it happen i read the code and it went bad right away 151 two day pay just like to be sure thanks
zx250's Avatar
zx250
Of the next Riffraff East
Again, Ditto, I suggest changing it soon because one of these times, and probably soon, it want restart. Welcome to the board and let us know if this works or not. When you have a chance fill out you signature so we will know a little more about your truck.
