Folks my for dealer told my cam positioning sensor is bad the cost $ 490- 575
I have a 2000 7.3 .where can I buy the part and where is this thing at under my hood. thanks a ton this site has helped me tremendously before. Ron
$500 for a CPS replacement is why we call them "Stealerships". even from ford, the part is only $250. you can go to the International dealer, get one for half of that, or even buy a new one off ebay for $70, but you would have to wait for it to come in.
if you look on the crankshaft from the bottom of the truck, it is in the 10 o clock position from the front. here is a picture of it.
you can install it yourself in 10 minutes or less with a 10mm socket..
just like strokin said. Ebay if you have the time to wait. Even if you pay extra to overnight it usually it is cheaper. Or international. It is easy to replace and save yourself a good chunk of change for other fun stuff to do to your truck. f Goodluck
Does he swallow too? I got mine for under $110 and that included tax and no haggling at the International dealership. If you want to pay me for shipping I could next day one to you tomorrow. Still better than $490
the part you are looking for is the timing indicator arrow. Use a 3/8 ratchet with short extension and 6 pt socket (10mm) to remove and reinstall with some o ring lube or motor oil on the o ring. The wire is held in with plastic retention lock. Lift the lock and pull apart. Wiggle the sensor when removing from the front cover. Its probably the original so it may be stuck but will come out with some coaxing. Its designed to go back together easily.
I had several online communication in regards to my CPS and what my 2000 F350, 7.3 was doing....well I replaced my CPS and it is still doing the same thing. Intermittent Stalling, dying, no throttle reponse. This happens for about the first 2 to 3 dyings and startings. Any other ideas to what else might be the problem???
