Bad TPS symptoms
Old Jul 3, 2006 | 10:30 PM
ptt's Avatar
ptt
Bad TPS symptoms
It's a 1995 E150 Conversion w/5.8 & E4OD showing 193K miles. This is an ongoing intermittant problem. Not showing any codes on my scanner. Yesterday while taking a 40 mile trip on the interstate highway the OD "OFF" light on the stalk began flashing again and when I exited and started off from the stop sign it shifted hard in all gears but harder 1st-2nd. Van sat for about 2 hours and the return trip was uneventful. Fluid is good and red and full. Could this be a TPS starting to go or does the TPS set a code when it goes out? Thanks.
Old Jul 4, 2006 | 08:54 AM
Clubwagon's Avatar
Clubwagon
If the OD light is flashing, there is a transmission code. Its not likely a TPS code but its possible. I would first expect an overtemp code or a torque converter slip code.
You need to have the transmission codes checked.
Steve
'95 Clubwagon XLT
Old Jul 4, 2006 | 09:32 AM
subford's Avatar
subford
You may have a VSS sensor problem, if you are vary careful you can take it out wipe off the end and put it back in.
If this fixes it you need to change the oil in the rear end.
iwals
Sep 14, 2023 05:22 PM
NotEnoughTrucks2014
Mar 5, 2017 12:37 PM
Imleadguitar
May 25, 2016 02:56 PM
big ole ford
May 22, 2016 11:06 AM
87-XL-Squared
Feb 26, 2016 07:52 AM
