1978 - 1996 Big Bronco
Kill Switch wire nut failure
Old Jul 5, 2006 | 05:49 PM
Dutch123's Avatar
Dutch123
So,... a buttsplice connector is what?
Old Jul 5, 2006 | 07:22 PM
BroncoRoadKill's Avatar
BroncoRoadKill
http://happyterminals.com/images/3B-P.jpg
You incert both wires into it either side and crimp it, then cover in heatshrink.
You can also buy the insulated ones from an autoparts store or radio shack. they may be easier for you, but either way works good.
The heatshrink method is a must on connections out side the truck that will be in the weather.
Old Jul 6, 2006 | 11:36 AM
Dutch123's Avatar
Dutch123
Thanks BRK- I used scotchlock that came w/window motor and 3 times I have had to dig in there- you know get to the motor- and reset the connection. Since these scothclicks came with the motor- I used them. I'll try the splice
out
Dutch
sandyc
Sep 1, 2010 03:38 PM
fzeed
13
Feb 18, 2009 04:06 PM
dustinova
Electrical Systems/Wiring
Dec 14, 2006 06:36 PM
T18skyguy
22
Sep 12, 2005 11:42 AM
RJLB
Apr 14, 2002 02:25 PM
