brakes
Old Jul 3, 2006 | 12:31 PM
RobPStroker's Avatar
RobPStroker
brakes
hey all just going over my 77 highboy today to get ready to put it on the road i wanted to check out the rear drums and brakes thats where i got stumped how do you get the drums off?
Old Jul 3, 2006 | 01:17 PM
Mil1ion's Avatar
Mil1ion
There are numerous threads about Dana axle drum removal in the brakes forum
EDIT:I found this for you.
https://www.ford-trucks.com/forums/s...d.php?t=437563
Old Jul 3, 2006 | 02:00 PM
1975Ford's Avatar
1975Ford
Like to add, replace the inner seals, and replace the 8 bolt hole axle gasket.
The big nut that holds the drum and bearing has a locking tab which must be removed before attempting to remove big nut.
buck
Old Jul 4, 2006 | 07:21 AM
RobPStroker
thanks
thanks for the help guys
Old Jul 5, 2006 | 08:45 AM
1975Ford's Avatar
1975Ford
This would be a good time to replace the rear axle gear oil.
Make sure to refill the axle up with gear oil, to get the gear oil on the wheel bearings.
