how do i get the knobs off
Old Aug 5, 2000 | 11:20 PM
69man's Avatar
69man
how do i get the ***** off
how do i get the ***** off of the light, wiper, and choke ***** off
please help me
69man
Old Aug 6, 2000 | 12:29 AM
390fe's Avatar
390fe
My '70 has small allen set screws in the *****. The headlight switch, you have to remove the **** and shaft as a unit. There's a small button on the headlight switch you can push that will release the ****.
Jason
Old Aug 6, 2000 | 12:40 PM
jowilker's Avatar
jowilker
Garth, some of the older ***** are held on by a spring action Z shaped piece of metal and have to have something pressed against it to releave the tention and make the hole round and it should come off.
There has to be a better way to describe that.
John
jowilker@nc.freei.net
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Aug 6, 2000 | 03:15 PM
red68ranger's Avatar
red68ranger
Ford had a few different ideas here and couldn't decide which was better so they used them all.
1. There's a little button on top of the light switch that you have to reach under the dash and push down on. The light switch shaft, which the **** is molded onto will pull out if you hold the button in.
2. The choke **** is molded onto the shaft which is crimped onto the cable. Short of breaking something, the whole thing comes and goes as a unit.
3. There's a little clip on the back and inside the ww switch ****. I haven't taken this one off yet, but Haynes says there's a "hooked" tool to reach in back there. A paper clip might do it?
Dan Blackwell
Old Aug 6, 2000 | 05:23 PM
dave186's Avatar
dave186
I made a special tool to get the wiper know off, bend the end of a small screwdriver around like a hook and pull against the metal clip.
Dave
http://www.davesmonsterpit.com
Old Aug 6, 2000 | 08:42 PM
250two_by's Avatar
250two_by
The small screwdriver thing works. There has to be a gazillion people who do it this way. If you're limber, lay on your back with your feet on the floor of the garage,ground and use a flashlight to see where to hook the "tool".
Old Aug 8, 2000 | 08:43 AM
rdscofield's Avatar
rdscofield
hermannm2
2009 - 2014 F150
Sep 26, 2013 03:08 AM
xc4jokestomper
May 21, 2011 09:02 PM
smoke n tires
1983 - 2012 Ranger & B-Series
Aug 21, 2008 09:11 PM
kooper909
May 23, 2006 02:31 PM
Robert Red Ford
Jan 16, 2003 01:21 AM
