AIC (apcm) inop
Old Jul 2, 2006 | 02:12 PM
kbeefy's Avatar
kbeefy
AIC (apcm) inop
OK, so I just bought a 2000 f350 w/ 7.3, and while fiddling with all this cool new stuff I've got (first diesel) I've discovered that the AIC isn't really doing anything. It powers up on startup and read rpm fine, buttons seem to affect it but it doesn't alter the rpm. A friend told me the truck needs to be parked w/ ebrake applied (it's an AT) so I did that and still no luck, but I did notice that the ebrake light doesn't illuminate on the dash, for whatever thats worth.
Any suggestions?
Old Jul 23, 2006 | 04:49 AM
Green_Dually's Avatar
Green_Dually
Any suggestions?
yes e-brake needs to be on.Try this,with ebrake on push the ovel button that says ford.Then push the button that says charge protect.
Old Jul 23, 2006 | 06:15 AM
Uzumati's Avatar
Uzumati
Any suggestions?
If what Green Suggested doesnt do it. Could be the P/E Brake position sensor gone bad and the AIC is not getting the info that it is on.
Old Jul 23, 2006 | 08:59 AM
Kwikkordead's Avatar
Kwikkordead
The parking brake switch is a little contact mounted on the side of the parking brake pedal assembly with a single wire going to it. If it's loose or disconnected the light won't come on. You could try a workaround to diagnose the non-response by grounding that wire so that the light comes on and the ECU gets the signal that the parking brake is on. Don't leave it that way because the light will stay on and the ECU will command a beeper to sound whenever the truck is in motion.
Old Jul 23, 2006 | 11:22 AM
Medic 66's Avatar
Medic 66
The APCM has to know that the light is on in the dash or it wont engage.
superduty4x4
15
Sep 6, 2021 10:50 PM
superduty4x4
Jan 10, 2011 10:32 AM
superduty4x4
Apr 7, 2009 02:55 PM
bbsst
Nov 14, 2008 01:00 AM
