1978 - 1996 Big Bronco
Another 'Not Starting" Issue
Old Jul 2, 2006 | 08:16 PM
captainl67's Avatar
captainl67
yep put somthing on the crank and try turning the engine.
Old Jul 2, 2006 | 08:19 PM
althund's Avatar
althund
try tomorrow.....do I have to take the plugs out, or will I be strong enough with a breaker bar?
Is it common for a motor to just seize up without any warning? I take good care of it and the motor only has 45000 on it (second one)
Old Jul 2, 2006 | 08:22 PM
captainl67's Avatar
captainl67
cold have dropped a valve on shut off . but you would be able to turn with plugs in key off and out of ignition of course. good luck.
Old Jul 2, 2006 | 08:30 PM
althund's Avatar
althund
wife is going to kill me if it seized. What is your gut telling you?
Old Jul 3, 2006 | 06:34 AM
SOUP 87's Avatar
SOUP 87
Hi althund
My gut feeling is that you have a bad wire connection somewhere. Look at all your big cable connections.
First make sure your bat is fully charged. Next take a jumper cable and run it from the negative post on the battery to the mounting flange on the starter. Not where the positive cable goes, but the frame of the starter.
The chances of the engine being froze up is slim.
Poor grounds do more wierd things to cars than just about anything I know of.
Hope this helps Steve
Old Jul 3, 2006 | 07:49 AM
althund's Avatar
althund
whew, the motor isn't siezed. Time for a mechanic.
Old Jul 3, 2006 | 08:18 AM
althund's Avatar
althund
Soup, I'll try that. I am beginning to wonder if there is a grounding issue in the back related to my fuel pump install.
Old Jul 3, 2006 | 02:15 PM
althund's Avatar
althund
Thank you Soup. It was the negative cable on the battery. Replaced it and it did the same thing. So I ran the ground to the starter and will look into it further in the future.
Thanks agian.
Old Jul 7, 2006 | 10:14 AM
Bronco Man's Avatar
Bronco Man
Smile
Try pulling the starter and see if it turns over. Starter could be bad. Maybe a bad cable or connection. Keep it simple.
Old Jul 7, 2006 | 10:52 PM
IanCT's Avatar
IanCT
Maybe have your starter tested at another location. My neighbor and I scratched our heads on the starter in his Olds, didn't work in car, tested good at the local parts shop, tried it again in car, not working. Pulled it out and tried it out of the transmission housing and it spun. Tested it at another shop and it turned out bad. Somehow the windings or bushings were shot but made good connection in a position other than normal. How old is the starter? Might not hurt to try a new one.
Old Jul 8, 2006 | 07:45 PM
BRAWLNBRONC's Avatar
BRAWLNBRONC
you mentioned that youre steering no longer locks and that a mechanic had just bein through there and and he replaced some bolts in the linkage . i would make sure that youre linkage is properly adjusted if youre car is not in park it might not let the starter turn over for safety reasons
Old Jul 9, 2006 | 01:11 PM
scoutpup99's Avatar
scoutpup99
Wink
Try replacing the cable from the battery to the solinoid. I had this cable fail on me twice. Both times it looked good and measured no resistance until i loaded it. If the cable is bad it will let enough power through to power your lights and such but as soon as you try to power the starter it will just go dead until you let go of the key. let me know what you find.
Dan Pennington
69 IH scout800A
90 Ranger 2.9 (322000 miles)
89 F350 Crewcab Dually
81 F350 Flat Bed 4X4
92 Bronco 351
01 Expedition
DomFili
Electrical Systems/Wiring
Jul 3, 2016 08:29 PM
ollirrap
Dec 18, 2012 09:38 AM
master_mechanic
Offroad & 4x4
15
May 26, 2009 08:59 PM
ttow
Feb 12, 2008 09:04 PM
