Backpressure Sensor Alternative?
Old Jul 1, 2006 | 10:01 AM
marvinlong's Avatar
marvinlong
Can you cap off the manifold where sensor tube attaches and wire open the EBP butterfly with no ill affects? Reason I ask is I'm unable to unscrew the old sensor without doing harm to the rest of the componant. Will likely let a pro. mech. do it at a later time towards cold weather. ( like all the new smilies!)
Old Jul 1, 2006 | 10:47 AM
wlihntr's Avatar
wlihntr
you can just cap them both off. someone did a write up on how to do it. i think it was jtharvey, let me see if i can find it
here you go, it was jt: https://www.ford-trucks.com/forums/s...d.php?t=495035
Old Jul 1, 2006 | 12:31 PM
marvinlong's Avatar
marvinlong
i think that is what i'm looking for. i've been getting a PO472 code which is BP sensor low input. thanks
Old Jul 1, 2006 | 01:52 PM
mech2161's Avatar
mech2161
You can get a code eliminator here http://www.blackclouddiesel.com/Ford/codepigtails.htm#code2 look toward the bottom of page.
In this pic you can see I used the port to check drive pressure.
Old Jul 1, 2006 | 03:29 PM
jtharvey's Avatar
jtharvey
Yes, you can cap it off. See my thread that someone posted above. Just be really careful if it starts to get cold. That sensor is used for sure (among other things possibly) to tell the computer when to open the EBPV if you're applying throttle. Without it being able to sense backpressure, it will leave the valve closed thinking there is none. Then you'll have virtually no power and could overheat some vital components if you continue to give it some throttle. I have my EBPV on manual control, so this is not a worry for me. I had the code eliminator, but after Cat_Man had his fail and lose some power, I took it off, put the sensor back on, and capped the tube and sensor. I don't think my code eliminator was bad because the truck ran the same after I put the sensor back on.
Old Jul 1, 2006 | 09:27 PM
marvinlong's Avatar
marvinlong
thanks,i plan on fixing it right before it gets cold. the #^*@ sensor is siezed. i sprayed it with penetrating lube but no dice. so i dont need to wire the valve open? this all started thinking the valve was stuck shut as i get skyrocket egt's and little boost. again thanks,great post jtharvey
i eat hybrids
Modular V10 (6.8l)
Feb 25, 2018 05:23 PM
therigwelder
42
Dec 19, 2015 09:02 PM
JSTJ704
Jul 23, 2014 07:44 PM
HotRodTroy
2004 - 2008 F150
May 6, 2014 08:19 PM
nimrod6979
Jul 21, 2004 02:34 PM
