2004 Rear view Mirror Vibrating
Old Jun 30, 2006 | 05:19 PM
tonymusc's Avatar
tonymusc
I have the automatic rearview mirror that will adjust to evening lights. It is Vibrating at the first joint behind the mirror. Is there a screw I could tighten? Where could I get to it. Thanks.
Old Jun 30, 2006 | 08:51 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
If your side view is okay, you may be seeing first symptom of tires not balanced correctly. Does it get worse with increasing speed?
Old Jun 30, 2006 | 09:18 PM
tonymusc's Avatar
tonymusc
Even when the car is stopped it will vibrate from the engine turnning on and revving. Its really loose.
pin8246
Jul 13, 2012 01:00 PM
pit_of_pity
17
Mar 24, 2011 04:50 PM
dukman22
Jan 23, 2007 06:43 PM
Fishallot
1978 - 1996 Big Bronco
May 10, 2005 08:48 PM
