69 360 intake
Old Oct 5, 2000 | 09:08 PM
dmcadams's Avatar
dmcadams
69 360 intake
Hi guys! Was hoping someone could tell me if there is a heatshield or something under my 360ci intake. Called the parts store today to price a head gasket set and they said it didn't include the heat shield. When I asked what it was he didn't know and they couldn't find it in there system. I can't take the motor apart till I figure out everything I need so any help would be greatly appreciated.
Thanks,
Don
Old Oct 5, 2000 | 09:20 PM
StockMan's Avatar
StockMan
69 360 intake
[FONT COLOR="#0000ff" SIZE="+1" FACE="Veranda"]
There is a "baffle" under the intake which is designed to keep engine oil off of the heat passage that goes through the intake manifold, but that item is generally not "replaced" rather the rivet is removed and you clean out any oil deposits in there. I would think they might be referring to the heat shield type exhaust manifold gaskets which protects the plugs/wires.
[/FONT]
http://members.aol.com/tbeeee/page/67registry.jpg
http://www.hometown.aol.com/tbeeee
Old Oct 5, 2000 | 09:36 PM
dmcadams's Avatar
dmcadams
69 360 intake
Thankyou very much, thats all I needed to know.
Don
Old Oct 6, 2000 | 06:34 AM
jowilker's Avatar
jowilker
69 360 intake
Don, I agree with Thom on the part. I just pulled and resealed an intake. You will have to pull it before you know weather it's in there or not. I got several more recommendations to leave the sheild, rather than remove it, for what it's worth.
Get a Fel pro gasket set and a tube of rtv silicon, and after you get it all drained down, and apart the reseal is simple. ;-)
John
jowilker@nc.freei.net
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Oct 6, 2000 | 06:58 PM
skip4274's Avatar
skip4274
69 360 intake
I can only add one thing to this post. Find yourself a used aluminum manifold and cut about 80 pounds off your motor. If you have a boat, the cast iron 360 manifold makes an excellent boat anchor.
Skip4274
4everFord
Old Oct 9, 2000 | 07:53 PM
StockMan's Avatar
StockMan
69 360 intake
Raptor119
Jun 12, 2009 04:18 PM
travisg96
Engine Swaps
May 21, 2008 04:22 PM
HFMotorsports
21
Jul 22, 2006 08:10 AM
whiteyford
Mar 16, 2004 05:39 PM
Jakes69
18
Dec 21, 2003 02:22 PM
