Hood won't open
Old Jun 29, 2006 | 11:32 PM
buster23's Avatar
buster23
Cool Hood won't open
I have a 2000 Explorer XLT 4 door w/ 5.0. The hood won't open. I don't see an 8mm bolt to disconnect the latch, and the cable has no tension. It had tension until I monkeyed with it. I broke the first law in do it yourself maintenance. "To do no harm" I had someone engage the hood latch while I pushed and pried and beat on the hood. No luck. Any suggestions?
Old Jul 2, 2006 | 01:13 PM
jhonda650's Avatar
jhonda650
Hey I feel your pain. I have a 2001 Explorer XLT 4x4 and my hood release has always seemed loose. I think it was loose before i hit my deer, but it was definately loose after it was repaired. IT would always pop for a year and a half after the accident, till it got worse and i coudnt get it popped. The way i had to get it open is to prop the lever open under your dash, then crawl under the truck and gently pull the cable. WE then adjusted the cable so i dont have to crawl under the truck anymore.
Hope that helped!
John
Old Jul 3, 2006 | 01:58 AM
buster23's Avatar
buster23
Hey John, thanks for the info. I will try just about anything right now.
Old Jul 3, 2006 | 04:51 AM
jhonda650's Avatar
jhonda650
i happened to use a lighter to prop the lever open. try to get it all the way, and then you shouldnt have to pull the cable very hard.
Rich56
Apr 10, 2013 01:03 PM
fordbroncodave
1978 - 1996 Big Bronco
Mar 25, 2010 01:29 PM
woodworx
Dec 2, 2007 05:15 PM
JoeVB
Aug 15, 2006 04:40 PM
