Bronco II Ford Bronco II
Windshield washer pump not working
Old Jun 29, 2006 | 11:56 AM
bones68's Avatar
bones68
Lightbulb Windshield washer pump not working
I have an '87 Bronco2 4wd 2.9L 5 spd tranny. I am trying to get the windshield washer pump to work. It gets 12-14 volts when I pull the switch but it doesn't turn on. It's a new pump and it works if I run it directly across the battery. Please give me some ideas..
Old Jun 29, 2006 | 10:39 PM
LarryA's Avatar
LarryA
You may have the pump pushed in the tank too hard. I had the same problem with my '90 and what happened was that if pressed in too far the inpeller was making contact with the tank and wouldn't tun.
? Something to look at anyway?
Old Jun 29, 2006 | 11:03 PM
bones68's Avatar
bones68
Thanks for the reply.. But the pump is out of the tank so I can see if the impeller turns and nothing.
Old Jun 29, 2006 | 11:35 PM
shiloh66's Avatar
shiloh66
Bones try grounding the other wire to the truck somewhere and see if it works
Old Jun 30, 2006 | 12:19 AM
infoguy's Avatar
infoguy
Sounds like the ground from the switch.It works accross the battery because you have a proper ground. Use a 12 volt probe to ***** the stock power wire to verify 100 percent power is there.Then use one of those cheap blue fold over crimp type things to bypass the the stock ground wire with a small lengh of new wire to the nearest clean metal surface and drill a little hole for a ground screw. It should work after that. been there with my '85
Old Jun 30, 2006 | 01:44 AM
87 XLT's Avatar
87 XLT
I agree, sounds like a bad ground.
Old Jun 30, 2006 | 10:20 AM
kernel-panic's Avatar
kernel-panic
Again, probably part of your battery drain problem. Could be a bad multi-function switch ... moreso the wiper/washer part than the turn signal part... or even both. Sounds like you inherited a lot of electrical system demons that must be vanquished!
Old Jul 5, 2006 | 09:24 AM
bones68's Avatar
bones68
I tried grounding to the firewall but no response. So I went to a junk yard and found a multi switch and swapped it out with mine and it worked..
Thanks everyone!!
joebiii
13
Sep 10, 2016 01:14 PM
BOBFIDY
Jul 11, 2016 08:00 PM
NDL
1983 - 2012 Ranger & B-Series
Apr 20, 2016 07:59 PM
9explorer8
Sep 8, 2010 03:09 PM
cbfomoco
Mar 13, 2007 12:04 PM
