1966 - 1977 Early Broncos
Power Steering Box
Old Jun 28, 2006 | 08:50 PM
xlrs's Avatar
xlrs
Power Steering Box
Hello All,
Got a 69 Bronco and I want power steering.My question is... Are all the power steering boxes from 73 to 77 the same? Will they fit a 69? Any help would be greatly appreciated.
Thanks
XLRS
Old Jun 29, 2006 | 01:09 PM
RCrawler's Avatar
RCrawler
Externally, they are the same. But there is 2 different ratios. The 73-75 5.5 turn and the 76-77 4 turn box.
The power box will bolt in place of your manual box. You will need to make some changes to the steering shaft to mate the column. There are aftermarket shafts available, as well as used factory setups. Or you can build your own with your existing shaft. Ford had different pitman arms for power steering, but the manual pitman arm will work. FYI, the 76-77 pitman arm is unique and won't work with your '69s steering linkage.
HTH,
Jason
Old Jun 29, 2006 | 10:43 PM
xlrs's Avatar
xlrs
Thanks RCrawler. That is exactly what I was looking for.
xlrs
xlrs
Utah Chapter
Jul 23, 2010 11:22 AM
xlrs
Jan 3, 2009 07:20 PM
xlrs
Feb 20, 2006 07:19 PM
xlrs
Utah Chapter
Feb 12, 2006 07:03 PM
xlrs
Utah Chapter
Jan 1, 2005 06:20 PM
