No drunk monkeys!
Old 06-28-2006, 08:16 PM
Code3's Avatar
Code3
Code3 is offline
No drunk monkeys!
Hey folks! I was just wondering when the steering starts to show signs of play in these old trucks. Is it a mileage thing, a time thing, or a combination of the 2? The reason I ask is because I have absolutely no play in the stock steering setup of my newly acquired '60. The seller said the 35.9k miles on it are all original. I may be a little more inclined to believe him now, unless there's a possibility I overlooked something.
Old 06-28-2006, 08:48 PM
3Mike6's Avatar
3Mike6
3Mike6 is offline
Really depend on how it was driven and under what conditions.
I/e a 100K mile highway truck would probably have less play that a ranch truck with 10K miles on it.
Old 06-28-2006, 09:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Also depends on whether it was greased regularly. My experience in the West is that grit gets in the grease and grinds it to pieces, so it is more of a function of time than mileage. Regular re-greasing pushes out the grit.
Old 06-28-2006, 10:14 PM
51ford fan's Avatar
51ford fan
51ford fan is offline
Sounds like the PO took care of it
Old 06-28-2006, 10:23 PM
raerjim's Avatar
raerjim
raerjim is offline
Sounds to me like someone has adjusted all the gear lash out of the steering box in an effort to tighten it up to sell, and maybe gone too far.. hard to tell from here. LOL
Old 06-29-2006, 12:43 PM
AXracer's Avatar
AXracer
AXracer is offline
The worm and sector boxes are highly maintainance dependent, I'd recommend cleaning out the old, likely caked up lube out of it and put in fresh lube. The best way to tell if it's been tightened excessively to hide a worn out box is the disconnect the drag link and rotate the steering wheel from lock to lock. An over adjusted one will feel tight, notchy or grinding in the straight ahead area. It's likely your's is in good shape at that low milege if the truck has set for some time, but do re-lube it to keep it that way.
Old 06-29-2006, 01:34 PM
Code3's Avatar
Code3
Code3 is offline
Thanks for the input fellas. I just got my shop manual today...feels like christmas!
Old 06-29-2006, 04:16 PM
reamer's Avatar
reamer
reamer is offline
Just wait till you start "wrenching" on it, It will feel more like "Tax Day the Christmas!
Reamer
Old 06-29-2006, 09:14 PM
raerjim's Avatar
raerjim
raerjim is offline
I just re-read my post on this subject, something I probably should have done b4 hitting the "enter" button the first time. It looked like I am accusing someone of something shady,which I did not intend. I apologize.
Jim
Old 06-29-2006, 10:46 PM
Code3's Avatar
Code3
Code3 is offline
Jim
Not needed. I used to sell new and used cars, so I've seen some shady stuff! I wouldn't be surprised if some POs do stuff like that. I'm just hoping that's not the case here. I don't think it is.
texasjack
40
07-30-2023 12:04 PM
BigBlue92
09-06-2011 10:34 PM
buckeyebronco
1978 - 1996 Big Bronco
05-16-2006 05:21 PM
LesPaul
05-02-2003 08:46 AM
73Highboy
10-20-2002 02:35 AM
Quick Reply: No drunk monkeys!
