steering play.
Old Oct 17, 2002 | 07:26 PM
73Highboy's Avatar
73Highboy
steering play.
Old Oct 18, 2002 | 10:40 PM
starweb's Avatar
starweb
steering play.
[updated:LAST EDITED ON 18-Oct-02 AT 11:41 PM (EST)]what steps do I take to reduce steering play?
I have a 79 F-150 2 wheel drive with power steering.
Old Oct 18, 2002 | 10:51 PM
Torque1st's Avatar
Torque1st
Posting Legend
steering play.
Fairly $imple, replace anything that is loose or worn... Bushings, rod ends, kingpins, steering box (if it won't adjust). Slop seems to multiply itself.
There is lots of info here if you use the <SEARCH> function.
Old Oct 18, 2002 | 11:14 PM
starweb's Avatar
starweb
steering play.
Ok obviously I did not search in the right place or use the right words so could you coach me along. also. it is probably in the steering box because I recently had the frontend redone.
Old Oct 18, 2002 | 11:45 PM
Torque1st's Avatar
Torque1st
Posting Legend
steering play.
The search function is very limited at this time. You can try the following method until the new forum software is installed use:
[link:www.google.com/advanced_search?hl=en|Google advanced search]
Enter the phrase in the appropriate box plus the word FTE in the top box for single words. -by Earl, FTE User
How much of the front end was "done"?
Old Oct 18, 2002 | 11:51 PM
oft's Avatar
oft
steering play.
I cleaned mine up by replacing the rag joint between the column and box. Take a look at it. If it looks like crap, it may be your problem. Cost 11 bucks at NAPA.
Jayson
78 Ford F100, 351W
93 5.0 GT
92 Taurus Wagon
die hard ford fan.
Old Oct 20, 2002 | 12:46 AM
starweb's Avatar
starweb
steering play.
took it in for a front end alignment.they told me all the parts were good except for the rubber mounts that tie the I-Beams to the frame. replaced those with new ones and the alignment was good.
Old Oct 20, 2002 | 12:57 AM
starweb's Avatar
starweb
steering play.
I guess I am doing something wrong because I am getting nowhere with the search results. if someone could just direct me I would appreciate it.
Old Oct 20, 2002 | 02:35 AM
Torque1st's Avatar
Torque1st
Posting Legend
steering play.
Read post number 3 for advanced search methods. Otherwise it is just pick your way thru the "results".
[font color=red]As a Moderator I do not "Subscribe" to most topics,
send email/pm if you need a reply -Thanks![/font]
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
