2.9 bad injector?
Old Jun 28, 2006 | 02:18 PM
88bII85027's Avatar
88bII85027
2.9 bad injector?
Started hard starting when cold. But always starts if cranked 4/5 times, then off then crank again. Usually starts then on 4/5 cranks. But always starts. But starts great when hot.
Now seems needs more cranking when hot. Noticing also a fuel odor after turning it off after running when hot. Pretty strong, checked for leaks several times, got under truck no odor at all.
Tank pump is brand new, both high pressure pump, filter and bypass canister are only about 1 year old.
Only thing left I can think of is bad injectors. Weak springs etc. The vehicle has 410,000 miles on it, and just put 3rd engine in last Nov. But this is something just started about a month ago.
Any input appreciated.
Leigh
Phoenix, Az
Laneind@aol.com
Old Jun 30, 2006 | 12:03 AM
TigerDan's Avatar
TigerDan
Hi Leigh, and Welcome to FTE! Please take a moment to check out the Guidelines, they contain important info that you'll need when posting on the site:
https://www.ford-trucks.com/guidelines.html
Are these the original injectors, reinstalled on each engine? If so, with 410K on them, they may indeed need a little help but I'm not so sure they are the source of your problem.
Have you checked for codes? Always a good place to start with EFI. Even if you're not getting a CEL (Check Engine Light) there can still be codes stored in the computer. If you don't know how to check them, read this:
http://fordfuelinjection.com/?p=13
I'd also take a look at the fuel pressure, it should be in the range of 35-40 PSI.
Old Jun 30, 2006 | 06:47 AM
88bII85027's Avatar
88bII85027
Thanks, I have injectors on the way. Will try those then probably change the high pressure pump again if that doesn't fix it.
Old Jul 11, 2006 | 05:47 PM
yodavator's Avatar
yodavator
if it not the injectors try the pressure regulater before the pump its only bout $10 for the part
Old Jul 12, 2006 | 04:06 PM
Psychopete's Avatar
Psychopete
+1
This will help narrow down what the actual problem is.
Pete
dslpwr530
Apr 21, 2013 10:16 PM
NMattison
1997 - 2003 F150
Nov 8, 2007 09:51 AM
CallerDale
1983 - 2012 Ranger & B-Series
44
Sep 8, 2005 04:36 PM
BuiltToughF250
23
Dec 27, 2003 10:50 PM
