Excursion Frame is...
Old Jul 7, 2006 | 01:05 AM
housedad's Avatar
housedad
This is from the Ford spec sheets for the frame of the 04 model years
Maximum Side Box Section
Excursion--------------------------F250/350
7.27 x 2.82 x .201----------------6.87 x 2.36 x .224 (.226 05 model)
Section Modulus
4.16---------------------------------5.6 - - - (6.7 05 model)
No, they are not the same frame . The Pickup has a higher section modulus indicating a greater twist resistance. The Excursion has a lower modulus but has a taller web and wider flanges.
Measurements are taken just aft of the drivers door in both vehicles.
You can make your own stress analysis, but these figures they give us are for only a single section through the frame. you need cross sectional data for the entire frame to make a comparison.
I have a idea hat the frames are the same in the front, since that is where the greatest amount of SD parts are hung on, but diverge into a different size and position aft of the drivers feet.
My 2 cents...
Old Jul 7, 2006 | 02:21 AM
Monsta's Avatar
Monsta
Sit. Stay.
Originally Posted by housedad
I have a idea that the frames are the same in the front, since that is where the greatest amount of SD parts are hung on, but diverge into a different size and position aft of the drivers feet.
My 2 cents...
And seemingly mine based on post #3.
Caleb Cook
Apr 6, 2017 11:43 PM
idealtrucks
Nov 20, 2016 06:06 PM
landcrazy
Nov 14, 2016 05:02 PM
repren
Oct 8, 2016 08:12 AM
f100today
May 19, 2016 08:41 PM
