fuel gauge
Old Mar 3, 2001 | 07:38 PM
69f250mg's Avatar
69f250mg
fuel gauge
My gas gauge doesn’t work. I tried looking for one in a junkyard but the ones I find don’t work either. Dose anyone know where I find one?
Thanks
Old Mar 3, 2001 | 07:39 PM
69f250mg's Avatar
69f250mg
fuel gauge
ops forgot to say it's a 69 F250
Old Mar 3, 2001 | 10:05 PM
79supercab4x4's Avatar
79supercab4x4
fuel gauge
chances are very good that its not the gage itself if it still doesnt work after trying other ones. one way to test the gage is to trace the wire going from the tank to the gage and ground it with the key on. if the gage works then the needle should swing all the way full. it could be a bad connection back by the tank or a faulty in-tank sensor.
Old Mar 4, 2001 | 05:15 PM
royisme's Avatar
royisme
fuel gauge
Sorry, I don't really know how to fix that, but I did have the same problems on my 76 F-150 4x4, then I went through a creek and high centered it on my tranny, don't know what happened, but it fixed my gas gauge, although the new tranny beat my wallet.
Old Mar 4, 2001 | 09:39 PM
HiMe's Avatar
HiMe
fuel gauge
Could be a bad sending unit inside the tank. LMC and AutoKrafters sells new ones although not cheap.
Old Mar 7, 2001 | 04:44 PM
otto's Avatar
otto
fuel gauge
Old Mar 12, 2001 | 05:32 PM
mandelt's Avatar
mandelt
fuel gauge
[font size="1" color="#FF0000"]LAST EDITED ON 12-Mar-01 AT 06:34 PM (EST)[/font][p] Check the resistor on the back of the dash panel. It knocks it down to 6v. Check the sending unit with an ohm meter. Check the wire with the ohm meter.Make sure both sides of the fuse is hot.
Hope it works.
Old Mar 12, 2001 | 06:10 PM
69f250mg's Avatar
69f250mg
fuel gauge
your right, it was the resister. Thanks for the help
