dc
Old Jun 24, 2006 | 01:14 PM
DVAJJ's Avatar
DVAJJ
dc
I have two problems first I have a 99 f150 4x4 with a K&N generation II air filter it makes the truck stumble on take off, and second a intermittent whistling noise coming from behind the throttle body near the fire wall. Any ideas.
Old Jun 24, 2006 | 05:39 PM
LxMan1's Avatar
LxMan1
Welcome to the forum
Both problems are probably from a cracked PCV hose elbow at the rear of the intake manifold. This is quite common. You might also spray the MAF filaments with contact cleaner just ot make sure no filter oil has gotten on them, just don't touch them, they break easily.
Old Jun 25, 2006 | 02:00 PM
DVAJJ's Avatar
DVAJJ
Thanks for the info. Ford checked me out in the parking lot and said it was my K&N filter and some valve at a cost of $260.00 parts & labor. I'll check it out. Thanks again
Old Jun 25, 2006 | 02:37 PM
kspilkinton's Avatar
kspilkinton
The K&N type filters work better when you do a battery disconnect or PCM fuse removal to allow for the computer to "relearn" it's behavior.
-Kerry
Old Jun 28, 2006 | 08:11 AM
DVAJJ's Avatar
DVAJJ
That one didnt work, but thanks anyway
Old Jun 28, 2006 | 12:01 PM
pronstar's Avatar
pronstar
Clean the MAF and the IAC.
Bruker
1983 - 2012 Ranger & B-Series
Feb 24, 2009 05:12 AM
joeskeeter
Feb 21, 2008 10:23 AM
BIG-BAD-794X4
Offroad & 4x4
25
Feb 11, 2006 08:00 AM
ekers88
Engine Swaps
Jun 24, 2004 09:25 PM
stoab
Sep 10, 2002 01:13 AM
