I have little knowledge of them personally (as in, I know what one is but that's about it!) but when I'm looking for info on older tractors I go to a site called Yesterday's Tractors:
Kind of depends on the mower...some have live hydraulics, some don't. Most early Farmalls don't have live PTO, which is ok for mowing. Sucks for baling! If you want a really small tractor, look to the A, B, or Cub...The C and Super C is quite small too. H and Super H are a little larger and quite popular, M and Super M are the "big tractors", but in HP are quite small. Nice tractors, really nice.
We had a 7' bar mower that bolted to the drawbar of the M/Super M, probably would work on the H too. I've seen lots of Cubs and the others with a belly mower, which could be handier. All depends on what you are mowing and how much. Good for you for choosing Farmall and not those pesky weird sounding green tractors.
I had a Farmall Cub that was a great little mowing tractor- 60" belly mower if I recall. The 'A' is the next size up; the 'B' is a narrow front 'A', and then the 'C' is a little bigger. Cubs are very common, parts are plentiful. and you don't need a SuperDuty to haul it around. I think the 'A' is about 1,000 lbs. heavier. Oddly enough, I've noticed that small antique tractors often cost more than big ones- I guess because they're easier to transport, work on, etc.
