Engine Shutting Down
Old Jun 24, 2006 | 12:21 AM
400Nut's Avatar
400Nut
I got a 78 f250, 4x4, with 400, auto trans. Lately the engine has been shutting down at idle. It just shuts down, like the key switch has been turned off. It will fire back up instantly, only if I reset the switch to off position, then proceed to starting position. Anyone else ever have this problem?
Old Jun 24, 2006 | 09:06 AM
trinogt's Avatar
trinogt
Hmmm... Only when idling? Could possibly be flooding, but I would try a junkyard ignition module first. I carry a spare one with me.
Old Jun 24, 2006 | 06:58 PM
FordBoypete's Avatar
FordBoypete
I'm with tringot, check your Ign Module.
Next time it does it to you, Try this, pour cold water over it but do NOT RECYCLE your ignition Switch thru key Off + engine Off to Key On + Eng start + Eng on.
Pour cold water on the case to cool it, then go directly to Start, if it fires change your module. And stay away from "off brands". Get a Motorcraft if you can. I'd run a used Motorcraft before I'd run a new Wells or some other aftermarket brands. . . .
FBp
Old Jun 25, 2006 | 08:16 PM
trinogt's Avatar
trinogt
Yeah Pete, I had the same trouble with aftermarket Duraspark replacements. For the extra $20, the Motorcraft was well worth it! Went through two aftermarket parts in two months or so until going to the dealership.
btduckcall
Mar 7, 2014 07:00 PM
gfx4t
13
Aug 26, 2013 05:23 PM
dlueder
Aug 15, 2006 07:42 PM
faa_engineer
Dec 15, 2005 09:32 PM
Tomoco
Nov 30, 2004 10:01 AM
