Engine senser help
Old Jun 22, 2006 | 07:29 PM
ford88ranger's Avatar
ford88ranger
Engine senser help
This is hopefully a pretty basic question. Im rebuilding a 2.3L off of an 88 Ranger. Im currently getting everything back together but I am missing a sensor. It is located in the lower intake but my Haynes manual (surprisingly??) doesnt mention it. I have the other two sensors (ECT and IAT) but I cant figure out what the third one is. Looks like it screws into the coolant as well. Should there be 2 ECTs or what am I missing? Also, since I replaced the oil pump, do you guys recommend filling it with something like vaseline (or soemthing else) or just taking out the distributor and priming the system that way? Thanks in advance... David F.
Old Jun 23, 2006 | 12:49 PM
Rockledge's Avatar
Rockledge
Where are the 4-banger guys I wonder...?
I'll take a stab at it: I've heard of some Fords having cylinder head temperature sensors that are seperate and distinct from the ECT and the temp. guage sender. I do not know for sure if that's the case with an '88 2.3L.
Old Jun 25, 2006 | 08:17 PM
ford88ranger
Well thanks but I took a look at all the sensors specified for my engine at partsamerica.com and nothing seems to match up with what you described. I appreciate the help though. Any one else have a clue ?? Thanks again... David F.
mattoney
Bronco II
64
Aug 10, 2007 05:14 PM
dbarracuda
4 Cylinder Engines
May 26, 2004 08:06 PM
1976 ranger
Nov 4, 2003 09:37 PM
f100beatertruck
Apr 20, 2003 07:46 PM
spear52
Mar 14, 2003 10:46 PM
