stupid 4x4
Old Jun 21, 2006 | 06:39 PM
hownottodrive's Avatar
hownottodrive
stupid 4x4
With my buddies 3.0L 1999 ranger the 4x4 doesnt seem to be engaging. Is it one of those 4wd transfercases where you have to be rolling for it to engage? We got pinned trying to get over a rock and forgot to put it in 4WD before. Once we were stuck against it trying to go down the hill we couldnt move and the back tires just dug deeper. It was quite the pathetic stuck. There werent any weird noises but there was just no 4wd high or low. When we turned the switch the thing on the dash would light up when we put it in neutral and say whether we were in high or low but the front tires werent getting any power.
Old Jun 21, 2006 | 07:04 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jun 21, 2006 | 09:09 PM
bigdavesohc's Avatar
bigdavesohc
I think it has the pulse vacuum hubs, and those are notorious for turning into crap. You can go to warn for a manual hub conversion that is pretty cheap and easy to do, not to mention it gives you the reliability of manual locking hubs.
Old Jun 21, 2006 | 09:54 PM
Rockledge's Avatar
Rockledge
I don't know if you can get the '98-'00 Ranger AVM 470 replacement hubs through Warn. But they are available here in the US now.
http://www.tellico4x4.com/product_in...5eac1059c1cc72
Old Jun 24, 2006 | 07:52 PM
hownottodrive
is that last link for just one hub or the front pair
Old Jun 25, 2006 | 11:13 PM
hownottodrive
bump for reply
Old Jun 26, 2006 | 06:06 AM
Rockledge's Avatar
Rockledge
The price is per pair.
Old Jun 26, 2006 | 06:57 AM
woody_d87's Avatar
woody_d87
Does it sound like the t-case motor is turning? They are known for not wanting to work if you don't use them often. Does the light come on on the dash. Maybe I should have asked first if it was a manual t-case or push button.
Old Jun 26, 2006 | 04:07 PM
Alan D.'s Avatar
Alan D.
it's probably your hubs. mine dont work either. i was recomened to this cable system, to replace the vaccume system. it's about the price of manual hubs, but i like the idea of not having to get outside of the truck when you want to engauge the 4wd. but first make sure your tanfercase is engauging before you go working over the hubs. I doubt you want to put out 200 dollars to fix something thats not broke.
Here is the cable enguagement system. i dont know if it's compatable with Rangers or not. sent an e-mail, waiting for response.
Copy and past link, i dont know how to do url formatting.
http://www.4x4posi-lok.com/app_ford.html
Old Jun 26, 2006 | 05:30 PM
Rockledge's Avatar
Rockledge
In looking over the installation instructions, it becomes pretty clear that it's a fix for a different kind of 4x4 system than what the '98-'00 Rangers have (PVH).
Old Jun 26, 2006 | 05:37 PM
Alan D.'s Avatar
Alan D.
Really, would you happen to know if it's compatable with a 97 ranger?
Old Jun 26, 2006 | 06:28 PM
Rockledge's Avatar
Rockledge
No, it's not compatible with the '97 Ranger 4WD system (which doesn't use vacuum in any case).
Old Jun 27, 2006 | 11:50 PM
hownottodrive
the transfer case didnt seem to want to engage at first. After flicking it back and forth a few times though you can hear a slight hum from the transfer case and the dash light comes on. So I think the t-case is fine. Is there any way to check it?
Old Jun 28, 2006 | 12:02 AM
hownottodrive
Also does anybody have install instructions for installing manual hubs and do they fit with stock rims?
Old Jun 28, 2006 | 05:10 AM
woody_d87's Avatar
woody_d87
Crawl under, un-bolt the shift motor from the t-case, and have someone flick the switch. It should move i think a quarter of a turn. If it just barely moves, you may need to re-build it/get a new one. re-build is real easy. If you have ever taken a starter apart, it is the same concept, except smaller. Now an atv/motorcycle is pretty much the same size.
