240 timing jump?
Old Jun 21, 2006 | 12:03 PM
bluebird's Avatar
bluebird
240 timing jump?
can the 240 timing gears jump like a chain would? the truck started running rough one day then wouldn't start the next. it tries though.
Old Jun 21, 2006 | 02:27 PM
dendyr's Avatar
dendyr
They can if they are worn enuff to break off, Or come loose. Change your oil and look for metal shavings in the oil. that would tell you a lot.
Old Jun 21, 2006 | 03:03 PM
bluebird's Avatar
bluebird
i'll try that, but first let me give the whole picture....
pulled old truck out of barn after 15 to 20 yrs of sitting
replaced bat and cables, oil, plugs, wires, cap, rotor, points, and coil. hooked boat tank to fuel pump and checked fuel filter. added oil to all cylinders. truck ran. then an hour or so later it didn't run so we added more oil to cylinders, ran fine idled good, in fact ran good for about a week with short trips up and down the road at 45 max. then it did what i mentioned above. it ran rough one day and the next when i started it, it ran rough, died and hasn't started since. it tries but just won't start.
Old Jun 22, 2006 | 09:45 AM
dendyr's Avatar
dendyr
Check you pionts gap. It could have sliped shut on you. Mine use to do that all the time. After you do that then take your plugs out and wire brush them and put them back in. It could have fouled a plug.
Old Jun 22, 2006 | 09:53 AM
bluebird's Avatar
bluebird
Did that already but have not changed oil. hope to get to it this weekend. thanks anyway.
Old Jun 23, 2006 | 08:01 AM
312's Avatar
312
they mostly dont jump.just shear the teeth of and the camshaft stops turning.
Old Jun 23, 2006 | 03:20 PM
Redmanbob's Avatar
Redmanbob
1. I didn't see anything about rebuilt the carb. 2. How long was the gas in he Perco can ? 3. Was it 50/1 or regular gas. am I getting anywhere with this,, old fuel line, varnish in the bottom of the tank after 20 yrs..that vas reintroduced to the system when fresh gas was tossed on top ? just a thought
Old Jun 24, 2006 | 05:34 PM
bluebird's Avatar
bluebird
just a thought
ok i missed your post yesterday but here's where i'm at today.... 1 no carb rebuild.
2. new gas in boat tank hooked to fuel pump.
3. regular gas
4. using old fsteel line from pump to carb.
today i checked timing mark with tdc, with location of rotor.
all plugs have good spark so yes i think the next step is to rebuild carb. I know i should have done it first but i get so excited.!!! plus it seemed like timing. i'll check into a rebuild kit tomm. if i have time.
Old Jun 27, 2006 | 06:12 PM
bluebird's Avatar
bluebird
ok, i finished the carb rebuild, put it back on and still nothing. it tries to start but just wont. noticing a bit of smoke from breather while cranking. what next? should i pull the valve cover and check for a stuck valve?
Weston67
Sep 29, 2014 09:13 PM
cblewis
Jun 28, 2011 06:35 AM
Shaggie
Jun 2, 2010 11:23 PM
bean
Jan 11, 2006 06:32 PM
mattri
Jul 26, 2004 12:54 AM
