Intermittent Stalling
Old Jun 20, 2006 | 03:53 PM
zipper06's Avatar
zipper06
Unhappy Intermittent Stalling
I own a 2000 F350 7.3 Powerstroke. I am having problems with Intermittent Stalling. I can start the truck, it dies, start it again, it dies. Start it again and I have no throddle. I can start it again and it runs OK until the next time I use it and this process starts all over again. I had it on a diagnostic machine and it indicated "ICP too High". My "service soon" light comes on intermittently. I have changed oil, oil filter, air cleaner, and fuel filter. What does CPS stand for? I have read other owner's problems and they have simular stories and they mention CPS. Does anyone have any answers that could help me?????
Don
Old Jun 20, 2006 | 04:10 PM
vancouverpower's Avatar
vancouverpower
cps= Cam Positioning Sensor
It does sound like that is your problem. Around $120.00, one bolt one plug and its out.
Old Jun 20, 2006 | 04:11 PM
ryaneverk2's Avatar
ryaneverk2
Welcome to FTE, Don.
I think your problem does sound like it could be from the CPS. CPS stands for camshaft position sensor. You can take a look at this thread from the sticky at the top of the page:
https://www.ford-trucks.com/forums/s...d.php?t=478168
It has info on changing the CPS. You can also do a search on CPS and limit it to this forum, and it will bring up threads relating to CPS troubles. Cheapest place to get a new CPS is Ebay, followed by an International dealer, and lastly from Ford.
Old Jun 20, 2006 | 04:27 PM
zipper06's Avatar
zipper06
Thanks to both of you for your help.......I will check in to it......
Old Jun 20, 2006 | 04:56 PM
zipper06's Avatar
zipper06
Could you tell me where the CPS is located????
Old Jun 20, 2006 | 05:33 PM
ryaneverk2's Avatar
ryaneverk2
If you go to the link I posted, and scroll down to post #19, you'll see another link I posted with a lot of info on the CPS, including changing it and where it's located and even a couple pictures.
Old Jun 20, 2006 | 05:50 PM
zipper06's Avatar
zipper06
I had a diagnostic reading and it indicated "ICP Pressure Too High". What does that mean.....
Old Jun 20, 2006 | 06:48 PM
catalinagoose's Avatar
catalinagoose
What is the actual code that set?
Old Sep 20, 2006 | 09:09 AM
billfishnut's Avatar
billfishnut
ICP stands for Injector Control Pressure. This should be regulated by the Injector Pressue Regulator (IPR). Not that I recommend throwing parts at the problem....
CrewCabLongbox
26
Aug 11, 2014 02:24 PM
mcguirehg
Jan 11, 2014 11:04 AM
DblD353
Oct 22, 2011 12:49 AM
jhe1964
51
Jun 8, 2011 05:50 PM
