exhaust pressur
Old Sep 18, 2006 | 10:13 AM
mattyg50's Avatar
mattyg50
exhaust pressur
has anyone replaced the exhaust pressure sensor tube?
i noticed that the tube is boke off right at the right side manifold
any suggestions, it looks like it rusted good on it
the truck has 110k
thanks
Old Sep 18, 2006 | 02:14 PM
westpsd's Avatar
westpsd
I replaced mine about 4 months ago. I had to buy it at the Stealership as it is a Ford only part. I think it was about $40 (which is crazy), but you should replace it.
Old Sep 19, 2006 | 02:43 PM
mattyg50's Avatar
mattyg50
what is this tube for or do?
Old Sep 19, 2006 | 06:38 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
the Exhaust Backpressure Sensor is one of the vital sensors needed in the engine control system that to the engine run correctly and efficiently. the tube just moves the sensor far away enough to put it in a convenient place,and also away from the heat of the exhaust manifold, or the epoxy in the computer board in the sensor would melt. one end of the tube connects to the manifold like you said, and the other end connects to the sensor, and the tube snakes around the front of the engine block, almost dead center in front of the HPOP reservoir, and an inch or two behind the serpentine belt.
Exhaust Back Pressure Regulator Valve Tube
(Ford) F4TZ-9D477-A
Old Sep 20, 2006 | 09:18 AM
mattyg50's Avatar
mattyg50
ok cool
i just ordered it
but the only thing it looks like it is badly rusted on
i guess i will run the engine to get it hot to remove it, i just dont want it to break offf in the manifold
