1978 - 1996 Big Bronco
Changing fuel filter
Old Jun 20, 2006 | 10:01 AM
davdogg39's Avatar
davdogg39
Is there anything special I should be concerned about when changing my fuel filter? (92 Bronco V8 351 EFI). I know i have to disconnect the possitive on the battery and depressurize by opening the gas cap but is there anything more? Thanks.
Old Jun 20, 2006 | 10:52 AM
1975Ford's Avatar
1975Ford
Depressurize the bleeder valve on fuel rail on intake. http://www.autozone.com/servlet/UiBr...3d8009ee25.jsp
Old Jun 20, 2006 | 12:00 PM
davdogg39's Avatar
davdogg39
thanks i knew there was something else.
Old Jun 20, 2006 | 06:44 PM
94 XLT White/ Silver 302's Avatar
Does the 92 use the quick disconnect fittings on the gas line. My 94 takes a special tool to remove the filter. If you need the tool you can buy it at the auto parts.
Old Jun 20, 2006 | 07:28 PM
aurgathor's Avatar
aurgathor
If you got dirt in the quick disconnects that can make it impossible to disconnect, but you can use compressed air to blow it out, or a needle/small pick to clean it out.
Old Jun 21, 2006 | 08:27 AM
davdogg39's Avatar
davdogg39
yea i took a look yesterday at the fuel filter and it has some dirt around the quick disconnects. Ill try to blow it out with some compressed air, it seems pretty loose the dirt so it should work. thanks.
Old Jun 21, 2006 | 08:45 AM
This is the tools I bought at Advance Auto for disconnecting fuel lines.
It was under $20.00 for both tools
Old Jun 21, 2006 | 11:39 AM
1975Ford's Avatar
1975Ford
place tool over fuel line, push the tool all the way in toward spring, push the fuel lines towards each other while pushing the tool inward and then pull fuel lines apart. The fuel lines should separate, and sometimes can be stubborn.
Old Jun 23, 2006 | 12:45 AM
davdogg39's Avatar
davdogg39
yep, looks like i am going to need those tools, anything to make the job easy . Going to do it this weekend .Thanks again
Old Jun 23, 2006 | 09:35 AM
1975Ford's Avatar
1975Ford
Use either car ramps or jack stands to lift the front end up. Will need quick disconnect tools for fuel line, and a flat tip screw driver. Use rags to help to keep thing clean.
After your done, it will be time to hit the showers.
buck
Old Jun 23, 2006 | 01:58 PM
poffutt's Avatar
poffutt
don't have a drop light around when the gas starts-a-spraying.
Old Jun 24, 2006 | 01:56 PM
davdogg39's Avatar
davdogg39
i was going to do the job after I changed my oxygen sensor, but after reading that I had to relieve the gas line pressure I stopped. I dont own a tool to release the pressure on the gas line. Will anything else work? I have jack stands to jack the front up but I didnt want to lose any gas, well not that much anyway .
Old Jun 24, 2006 | 02:50 PM
b4hntn's Avatar
b4hntn
I just let it sit several hours before crawling under. At 200 lbs I am not thin but for safety reasons prefer not to jack anything up unless really necessary. Just scoot around to a good working position that is not right under the filter.
Old Jun 24, 2006 | 03:07 PM
If you look at your fuel rail on the drivers side of the engine you will see a shrader valve with a cap on it at the end of the fuel rail. Remove the cap, release the pressure using punch, screwdriver etc. to push the needle in the shrader valve down to releave the pressure and your good to go.
Old Jun 24, 2006 | 04:50 PM
buckinbronco'95's Avatar
buckinbronco'95
grab a rag and wrap it around the filter. when the gas starts to drip the rag will catch a lot of it and create less mess
