Rev Limiter
Old Jun 20, 2006 | 09:45 AM
wilbur996's Avatar
wilbur996
Rev Limiter
Stock truck with manual transmission and no chip. Does the PCM have a rev limiter built in and if so what is the RPM?
TIA!
Old Jun 20, 2006 | 09:50 AM
Rancha9's Avatar
Rancha9
What, you haven't found it yet?
It should be right at where the red line is on the tachometer... I believe it's right at 3400 RPM. I don't THINK it varied from year to year, but I could be mistaken...
Old Jun 20, 2006 | 10:54 AM
PSNut's Avatar
PSNut
Talk to Jody Tipton and he can remove it for u.
Old Jun 20, 2006 | 11:20 AM
wilbur996's Avatar
wilbur996
Not sure if I found it yet. LOL!
No, I think I'll keep it. I'm not that hard on my truck but every now and then you got to blow black smoke on somebody. LOL!
Thanks
Old Jun 20, 2006 | 06:39 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
factory powerstroke rev limiter is 3400 RPM. it can run all day at anything below that, it won't hurt it. it is not adjustable without modfied programming.
Old Jun 20, 2006 | 09:44 PM
piotrsko's Avatar
piotrsko
it is also 93 mph with stock 235's and a 3.73 on my 2000. That is a lot less than 3400 rpm.
Old Jun 20, 2006 | 09:47 PM
PowerstrokeJunkie
the factory speed limiter is "97" mph. i hit it on the dyno around 2900 RPM... "they just had to do it in OD"
Old Jun 21, 2006 | 09:14 AM
Fraalan's Avatar
Fraalan
I think the rev limiter makes me exempt for emissions.
is this correct?
Old Jun 21, 2006 | 10:05 AM
cangim's Avatar
cangim
Each state/county is different, most if they test diesels it wont matter on the rev limiter or how many mods you have on it. They just want you to come down and hand over more money.
Old Jun 21, 2006 | 01:18 PM
Fraalan's Avatar
Fraalan
In AZ they check to see if the rev limiter is working, if so go to the front of the line and you pass. The pain in the *** part is you have to take the letter and go to DMV to get tags. beats having to worry about passing.
swirlparanoid
Dec 9, 2013 06:14 AM
BossGasser
6.2L V8
Sep 22, 2013 09:29 PM
ROBZ95XJ
Jul 7, 2012 09:57 PM
SickPup404
Apr 23, 2011 12:35 AM
MustangGT221
16
Mar 22, 2004 01:24 PM
