that block may not be aluminum--may be magnesium--but still can be welded--will need to block off areas of block with a heat dam--welder should know how to do this if hes worth his salt--remove everything you can out of the area to help out the welder--and yes--you can build up anything--and shouldnt have to helicoil the new piece--but maybe the other hole--and its probably metric--
Any idea how much this may cost? Ball park estimate.
94 Turbo is correct in his assumption that the other hole is stripped.
Public Service Announcment
You can hold a starter in place with a boat paddle and crank the motor. It's also very difficult to pull start a outboard motor with a rope.
