Correcting Specific Gravity to Standard Temp?
Old Jun 19, 2006 | 11:49 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Arrow Correcting Specific Gravity to Standard Temp?
I need to correct the specific gravity of a fluid to standard temperature, 60° F.
The specific gravity of the fluid is .994 and the temperature is 75° F.
Can anyone provide a link to a conversion table or have a book you can scan a page out of?
Scott
Old Jun 19, 2006 | 12:11 PM
bigdaddyII's Avatar
bigdaddyII
What type of fluid are you working with? Here is a basic table, hope it helps. It is the best I can do without more information. Hope it helps.
Old Jun 19, 2006 | 12:22 PM
seventyseven250's Avatar
seventyseven250
Different fluids expand and contract different amounts with temperature. So there isn't an accurate conversion factor that can be used for all fluids.
What fluid do you need? I have some engineering data books around the office that would have some common industrial ones listed.
or just google the name of the fluid and "thermal expansion" and you may get lucky.
Old Jun 19, 2006 | 12:33 PM
sigma's Avatar
sigma
The formula is:
Correction (to add on to raw hydrometer reading) = 0.00000359 temp^2 + 0.00006971temp - 0.00151687
In temperatures between 0oC and 40oC you can approximate the SG by adding 0.001 for every 5 degrees the sample is above the hydrometer's calibrated temperature (normally 60F) and subtracting 0.001 for every 5 degrees the sample is below the hydrometer's calibrated temperature
Old Jun 19, 2006 | 01:39 PM
horsepuller
FTE Emeritus
Thanks for the quick response, guys!
The fluid is aqua ammonia. Sorry I didn't mention that. I didn't think it would matter because the temp conversion for API gravity uses the same conversion table for all petroleum fluids.
So in the example I gave above, since the temp is 75° F, the corrected gravity would be 0.003+0.994=0.997?
I would like to be able to use that, but can you give the math for dummies translation of that? I'm having a hard time filling in the blanks.
0.00000359 (does what to) 75°F to the power of 2 plus 0.00006971 (does what to) 75°F, minus 0.00151687 plus 0.994 equals...
Thanks!
Old Jun 19, 2006 | 08:15 PM
Flash's Avatar
Flash
If you need any engineering values or processes, go here:
http://www.engineersedge.com/Design_Data.shtml
They have just about all of the bases covered.
Old Jun 20, 2006 | 08:21 AM
seventyseven250
The reason I asked about they type of fluid is that it will make a difference. Even between different "petroleum fluids" they will each have different correlations. Also, Aqueous ammonnia isn't a petroleum fluid.
The way to get the exact answer would be to use the appropriate equation of state, but that's probably overkill.
You'll get 90% of the way there using the correlations that have been given above. Depending on what you are trying to do here, that's probably good enough.
Old Jun 20, 2006 | 11:12 AM
horsepuller
FTE Emeritus
Thank you for all your help, pards.
CretePumper
Feb 24, 2009 11:54 PM
Tomcat7742
Aug 22, 2005 09:45 PM
RCM
Jul 1, 2005 06:57 PM
Raul
Jul 5, 2001 03:00 PM
