Floor Jack Fluid
Floor Jack Fluid
Over the years, my floor jack has peaked lower and lower -- any secrets to refilling with hydraulic fluid. Which I have heard is auto trans fluid (??).
TIA
Raul
w/ 81 F-100, I6, SROD, Carter 1V non-feedback carb, no A/C, no PS, no PB, but it gets me where I need to go
TIA
Raul
Floor Jack Fluid
Most good auto stores sell hydraulic fluid JUST for jacks. i would not mix trans fluid with what is there now, seals may not be compatable with it!!
__JOHN__Õ¿ö
FTE Club #7
Member-
http://www.cruisin-north.com/
Santa Rosa, Calif.
72 F-250
ICQ#6030753
http://www.ford-trucks.net/users/jbhf250/
https://www.ford-trucks.com/pictorial/big/1972_f250_2.html
__JOHN__Õ¿ö
FTE Club #7
Member-
Santa Rosa, Calif.
72 F-250
ICQ#6030753
Floor Jack Fluid
I would stick with a fluid that is rated for jacks. I am not sure if there is much of a differance between jack fluid and hydraulic fluid. I do know that there are differances between trans fluid and hydraulic fluid. I agree with the above post that the fluids mixed could cause a problem with the seals. It would probably work but I would not do it. Good luck. Jake.
Jakegypsum // Ford fleet, soup to nuts.
