ignition switch
Old Jun 19, 2006 | 01:56 AM
Sgt_Pepper17's Avatar
Sgt_Pepper17
ignition switch
my buddy owns an explorer and the ignition switch is toast. the little plastic clip on the side of the switch is broken. It houses the ground wire for the ignition. I was wondering how to pull the whole switch? Couldn't figure it out on my own in the blistering heat so I'm comin to you, the masses...
thanks...
Old Jun 19, 2006 | 09:04 PM
JerrySimm's Avatar
JerrySimm
You don't metion what year. Most of them are on the to of the lower area of the steering column. Usually they are just held on with a bolt and they have slots to allow proper adjustment. However, I don't recall a ground wire in the ignition switch. Usually it only directs positively charged circuits.
Old Jun 20, 2006 | 05:01 AM
Sgt_Pepper17
Yeah, I shoulda known that, just rewired my Mustang... IDK. This wire is black and comes from the ignition. I don't have a wiring diagram. But you say it's a bolt underneith the ignition switch? I'll look for it. Thanks...
Old Jun 20, 2006 | 08:26 PM
JerrySimm's Avatar
JerrySimm
Still not sure what year you have but here's a partial wiring diagram for a '92;
I don't see a procedure at the autozone site for the switch, but when I did the one on my '92 it only took around 10 to 20 minutes to change it.
By the way, are you the same Sarge as the one I've been talking to on the Mustang forum?
Old Jun 22, 2006 | 11:24 AM
Sgt_Pepper17
prolly.... mustangforums.com?
I've got an '84 GT 5speed ('78 302), and a 79 F150 400M C6 9"...
It's my buddy's truck but I don't think he's gonna fix it. See, he uses it because he fixes it but his buddy actually owns it and is behind on rent and getting to be kind of an Ahole so I don't see it getting done.
The wire is a black wire on the side of the ignition switch toward the key end... It's not part of the wiring harness that I can tell...
Old Jun 24, 2006 | 10:10 PM
JerrySimm's Avatar
JerrySimm
Yeah, I'm 90GTRagtop over there. I misunderstood. You mean the wire is near the lock cylinder at the top of the steering column as opposed to the ignition switch near the bottom of the column. It may be part of the multifunction switch wiring then.
Old Jun 27, 2006 | 04:15 AM
Sgt_Pepper17
hmmmm yeah i'm not sure.. i know the lock is broken and will just have to remove it. Thanks though...
ahurt1973
Oct 25, 2006 02:52 PM
aerodam
Aerostar
Feb 21, 2006 09:48 PM
Bronco-Red
1978 - 1996 Big Bronco
Jun 10, 2004 10:46 AM
Hammy
Apr 5, 2002 06:51 PM
