223 points burning up
Old Jun 18, 2006 | 02:01 PM
cornfeed's Avatar
cornfeed
Hi
I just replaced and gapped the points in my 1959 f100 with a 223. The old points were corroded which caused the engine to run rough under load. When i put the new points in the pickup ran great for the test run (2 miles)but started to run rough on my second trip (4 miles). The new points have a yellowish green tint to them already. I have 12 volts to the coil with the key on. Is this too much? I have not replaced the condensor yet. How can I test my regulator? Thank you for any help.
Mark
Old Jun 18, 2006 | 08:16 PM
3Mike6's Avatar
3Mike6
I'm more of an "other brand" guy, but have you removed the ballast resistor? That would cause full voltage to the points on a Ch**y back in the early days.
Old Jun 18, 2006 | 09:00 PM
WillyB's Avatar
WillyB
I agree with Mike - you got to put a ballast resitor in the circuit.
Old Jun 18, 2006 | 09:12 PM
cornfeed's Avatar
cornfeed
Thanks for the response guys. Is the resistor on the fender right next to the regulator? If I replace the coil with an internal resistor coil would that accomplish the same thing?
Thanks
Mark
rangerottis
15
Feb 9, 2015 01:42 PM
1948 F1dude
May 26, 2014 05:47 PM
Tomget
1983 - 2012 Ranger & B-Series
Sep 18, 2008 11:26 AM
Cultsociety
22
Mar 25, 2008 02:13 AM
paulmal
Electrical Systems/Wiring
Aug 23, 2002 05:18 PM
