223 spark plug woes
Old May 25, 2014 | 10:51 AM
1948 F1dude's Avatar
1948 F1dude
223 spark plug woes
I am trying to get my '48 running smooth and am at a point that I don't know what to do next. I put in new Autolites #46 and # 3 & 4 sparkplug is black with soot. Since Friday I have put in two sets of plugs I adjusted valves and new set Fri. ran good. Took it out on highway and ran good except a surge . Next day ran like dookie . Talking with one of the guys in my club and he suggested check rotor and cap . This morning I put new wires cap rotor plugs(gap 35) checked valves again, drove the truck two miles and pulled #3 &4 plugs and they are black. Truck ran good but still have the black plug. I am using Petronic as the points kept burning up after 200 miles. The only thing I can not do is timing. I plan on taking to a shop tomorrow. Any clues? Am I missing something? '62 223 with '58 head new distributor
Old May 25, 2014 | 11:20 AM
tinman52's Avatar
tinman52
Welder User
Are the plugs getting fouled with oil? Or smell like gas?
Have you tested the compression? Also could be running too rich as those 2 plugs are closest to the carb...
Old May 25, 2014 | 01:52 PM
rpaxton939's Avatar
rpaxton939
Dude....my book shows the plugs to have a gap of .025 to .029. Maybe your gap is too big.
Old May 25, 2014 | 02:25 PM
1948 F1dude
I think I found the problem. I had the carb too rich like Tinman52 suggested
Old May 25, 2014 | 04:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'd close the gaps to no more than 030". Otherwise it puts a load on the coil & Pertronix. No advantage to a big gap.
Old May 26, 2014 | 09:11 AM
38 coupe's Avatar
38 coupe
If you have the stock distributor with points you can time the engine without a timing light:
1. Note where #1 is on your distributor cap then remove it.
2. Manually spin the engine over (turn the fan or put a socket on the crank bolt) until the rotor is pointing near where #1 on the distributor cap was.
3. Look at the crank pulley, you should be somewhat close to the timing marks. Turn the crank to align the timing mark of your choice (I think about 5 degrees advance is a great starting place).
4. Loosen the hold down on your distributor. Retard the distributor and turn the ignition on.
5. Advance the distributor slowly until the points spark then lock the distributor down without moving it (I usually get to repeat the retard then advance a few times to make sure I have the distributor in the right spot).
6. Reinstall the distributor cap.
Congratulations, you have timed your ignition.
Old May 26, 2014 | 09:14 AM
Olweldinrig's Avatar
Olweldinrig
With a Petronic gap shouldn't be a problem.Even at .045 plus.
Old May 26, 2014 | 05:32 PM
1948 F1dude
Thanks guys. I adjusted carburetor and runs great . I am so happy I have to sit on my hands to keep from waving at people..")")
Old May 26, 2014 | 05:47 PM
rpaxton939's Avatar
rpaxton939
Keep calm and drive!!!!!!
DoofusOfTheDay
Nov 16, 2012 12:46 PM
fireman336
Dec 21, 2010 06:55 PM
Dr. Dirt
May 26, 2008 08:06 PM
Ranger GT2
Aug 24, 2007 08:26 PM
cleanLX
18
Dec 26, 2005 08:38 PM
