eletrical problems
Old Jun 17, 2006 | 11:10 PM
customcab66's Avatar
customcab66
eletrical problems
got a 66 4x4 the battery goes dead after it sit for a couple of days. All the stuff that I can be unplugged. Stuff like the horn and the stereo. It has been doing this since it got put back together from being painted. Has a new ingintion switch and battery.
Old Jun 17, 2006 | 11:49 PM
Sam_Fear's Avatar
Sam_Fear
have the altenator checked for a bad diode. Alot of car parts places have the stuff to do a free check.
Old Jun 18, 2006 | 09:54 AM
Putt's Avatar
Putt
Be safe!
Do you have a 12v test light? Unhook the positive post and put the test light in series there, if it is lit, you have a draw somewhere(note the brightness of the light). Now disconnect items(pull fuses) one at a time until the light dims or goes out, when it does, you have found the draw. For instance, to check for alternator problem, disconnect both the heavy + wire and then the small wires, if the light goes out there is a draw in the alt.
It is best to unhook the test light while you unhook each component to be sure no sparks occur, then reconnect to check the light. You can pull the fuses while the light is hooked up if you have one of those handy plastic fuse pullers.
shanes66charger
15
Jul 14, 2014 12:39 AM
1972RedNeck
13
Dec 29, 2011 12:24 PM
CrazyDog66
Feb 13, 2011 03:33 PM
rsalter66
29
Mar 24, 2008 06:55 AM
Mazlem
Aug 16, 2006 10:05 AM
