Battery Size
Old Dec 27, 2011 | 03:52 PM
1972RedNeck's Avatar
1972RedNeck
Battery Size
My '66 F250 4X4 had a group 24 battery in it when I got it. I now replaced it with a group 27. It still looks like a bigger battery will fit. Are they supposed to have a bigger battery than a 27?
Also, my battery is currently held in with a rubber strap. Is the band for around the top and the bolts still available?
Old Dec 27, 2011 | 06:51 PM
StevenhF100's Avatar
StevenhF100
Battery hold down bar and rods from a 67 mustang work great. maybe other years.
Old Dec 27, 2011 | 08:01 PM
spurredon's Avatar
spurredon
Living where it's cold, I've always put the biggest battery that will nicely fit into the battery box on everything I own. Even those that I don't drive through the winter months. Just my opinion though.
Old Dec 27, 2011 | 08:33 PM
1972RedNeck
That why I upgraded to a group 27. I have never seen a ford that takes a bigger one. I don't want to buy a bigger one and have it not fit.
Old Dec 27, 2011 | 08:34 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
R-27-F or R-27-FA were the largest batteries available thru 1979 F100/350's. Both are the same dimensions, the FA has more cranking amps.
C5AZ-10718-A = Original 1965/66 F100/250 2WD / 1966 F100 4WD (1965/69 LTD, 1967/69 F100/350 & 1967/69 Mustang/Cougar and etc) battery hold down bracket was metal with a rubberized coating.
Battery acid ate thru the coating and/or it flaked off, rust began. In 1970, Ford replaced C5AZ-10718-A with a plastic hold down bracket (D0DZ-10718-A) for use as a service part replacement.
D0DZ-10718-A was also installed in: 1970/72 LTD/Thunderbird/F100/350 / 1970/77 Maverick/Comet/Bronco / 1973 LTD, some 1974 LTD's.
Old Dec 27, 2011 | 08:36 PM
1972RedNeck
R-27-F or R-27-FA were the largest batteries available thru 1979. Both are the same dimensions, the FA has more cranking amps.
I think I have 1200 cranking amps now.
Are the hold downs still available? (Probably not)
Old Dec 27, 2011 | 09:34 PM
NumberDummy
1965 F100/250 4WD / 1966 F250 4WD used different battery hold downs than 2WD's.
C5TZ-10718-D for Group 45 & 55 batteries / C1TZ-10718-A for the 70 amp battery.
I have no pic of these, so I don't know how they were installed. I have a feeling they're rectangular, fit around the top edge of the battery.
There are 21 of C1TZ-10718-A available NOS / I'll list some of the sources if interested
Old Dec 27, 2011 | 09:40 PM
StevenhF100
Hold downs are available at many mustang parts dealers run around $10 or so. Googe 1967 mustang battery hold downs for a list of some.
Old Dec 27, 2011 | 09:56 PM
NumberDummy
Did'ja read what I typed in post #5 inre to the C5AZ-10718-A / D0DZ-10718-A battery holdown, which is the same as 1965/66 F100/250 2WD, 1966 F100 4WD and 1967/69 Mustang and etc?
The OP has a 1966 F250 4WD, the battery hold down is not the same! See post #7.
Old Dec 27, 2011 | 10:01 PM
StevenhF100
Nope, missed that, thanks for setting that straight. That's why you're the best.
Old Dec 28, 2011 | 12:46 AM
Buzz44's Avatar
Buzz44
Hey Bill if you could kind sir Id be interested in where to obtain that particular hold down. Thanks in advance.
Old Dec 28, 2011 | 12:02 PM
1972RedNeck
I would also appreciate it.
Old Dec 29, 2011 | 01:53 AM
NumberDummy
C1TZ-10718-A .. Battery Hold Down Bracket / Obsolete
VAN CLEVE FORD in Morton WA has ONE = 360-496-5999.
GRIESEL MOTOR CO. in Okarche OK has ONE = 405-263-7242.
HAVEN FORD in Haven KS has ONE = 620-465-2252.
WILBUR FORD SALES in West Union IA has ONE = 563-422-3881.
MATLOCK FORD in Franklin IN has ONE = 800-987-3673.
MANDERBACH FORD in Temple PA has ONE = 610-929-3659.
KINSEL L/M in Beaumont TX has TWO = 800-816-2894.
PARTS INTERNATIONAL in Farmers Branch TX has TWO = 888-727-0418.
SHARP MOTOR CO. in Pulaski TN has THREE = 931-363-2533.
GREEN SALES CO. in Cincinnati OH has SIX = 800-543-4959.
Old Dec 29, 2011 | 12:24 PM
Buzz44's Avatar
Buzz44
Thanks Bill Happy New Year. Ill make some calls.
SVTDriver97
13
Jan 27, 2016 01:36 AM
Spktyr
Mar 1, 2015 05:50 AM
tigman_tim
Jan 5, 2014 01:31 PM
LARIAT 85
29
May 30, 2012 11:35 AM
erica
Jul 21, 2011 06:59 AM
