truck overhaul, started.
Old Jun 17, 2006 | 04:34 PM
zanny's Avatar
zanny
1986 F150 4wd. Bought all new sheet metal. Fenders, rockers, doors, front and rear bumpers, grill, headlight bezels, bedside skins, hood. All new front to rear.
Did the bedskins today. Had to buy eight foot bedskins and cut them down to fit my, six foot bed. Here's a couple of pics.
Will be using panel adhesive on the bedside skins.
http://www.carpron.com/multisite/v/U...y/bed.JPG.html
http://www.carpron.com/multisite/v/U.../bed2.JPG.html
http://www.carpron.com/multisite/v/U.../bed3.JPG.html
Old Jun 20, 2006 | 08:07 AM
mississauga's Avatar
mississauga
The job is starting to shape up. How did you like the fit of the side panels? I assume the old panel had spot welds that were drilled out.Looks like the inner panel is galvanized.
Old Jun 20, 2006 | 07:43 PM
zanny's Avatar
zanny
The bedskins fit really good. Used a spot weld drill to drill out the spot welds.
And, yes, the inner panel is galvanized.
After the panel adhesive set up. I sanded the seam with 80 grit paper. Applied epoxy primer, then sanded with 80 grit, applied kitty hair bondo. Then sanded with 80 grit, and then applied body filler. Will get more pics.
The truck will be ready for paint on saturday. Took a week off to do the truck.
Old Jun 20, 2006 | 08:48 PM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
How much are those body panels? May I ask where you got them? The best deal I could find was $300ish, maybe a little more PER panel. I was hoping LMC Truck was a little high.
Ryan
Old Jun 20, 2006 | 09:37 PM
fords_forlife's Avatar
fords_forlife
looks pretty good, but what are you doing about the stake pocket holes. i would think it might look a little goofy with the front one sitting that far back.
FORDS_FORLIFE
Old Jun 21, 2006 | 06:25 AM
zanny's Avatar
zanny
Just so everyone knows. I'm an electrician by trade. Whenever I get laid off, or currently locked out. I work for a friend of mine, who owns a body shop.
FghtinIrshNvrDie, the bedskins were 160 bucks a piece. I got them from a local supplier. Action crash parts. Nationwide company that supplies aftermarket parts to body shops.
fords_forlife, I have a tool box that goes across the front of the bed. Never had enough tie down points, because of the tool box. I re-inforced the center hole. Now, when I need tie down points, I have them.
I look at it being unique. How many six foot beds have a center tie down point?
Old Jun 21, 2006 | 08:03 AM
FghtinIrshNvrDie
yeah, I really don't see the problem with the tie down hole at all. Just add another one if it's not suiting your needs. As far as looking goofy, humbug. I didn't even notice.
So I'm not able to order from action crash parts because I'm not a body worker, correct?
Ryan
Old Jun 21, 2006 | 07:13 PM
zanny's Avatar
zanny
Call them. They will sell parts to anyone. Also check out keystone automotive. They are action crash parts competitor.
Don't settle on the first price they quote you.
PM me.
Old Jun 21, 2006 | 10:11 PM
FghtinIrshNvrDie
very cool. I'll do all those things very soon.
Ryan
Old Jun 23, 2006 | 06:43 PM
Rocket Racing's Avatar
Rocket Racing
Ryan,
Just so you know, bedskins for a 94 are more expensive from Action crash as compared to the 1986 skins Zanny bought.
From what i can see in your pictures, you may want to consider a wheel arch repair panel, as it is significantly cheaper than a bedskin. It looks like this pic:
http://www.midwestfender.com/images/...D92-054-J1.jpg
Old Jun 23, 2006 | 07:11 PM
zanny's Avatar
zanny
Originally Posted by Rocket Racing
Ryan,Just so you know, bedskins for a 94 are more expensive from Action crash as compared to the 1986 skins Zanny bought.
I agree. I didn't know bedskins for a 94 was so expensive. Just checked, our online account. 315 bucks a piece in Cincinnati. Put in a patch panel.
Old Jun 23, 2006 | 10:56 PM
FghtinIrshNvrDie
I saw the patch panels... They're on broncograveyard for like $35 a piece, and that's great. But I was hoping I could do as little touch-up stuff as possible. 2 seams would be better than a whole mess of seams for each rust hole.
Ryan
Old Jun 23, 2006 | 11:01 PM
Rocket Racing
You can get a little more out of Action on them, say maybe the 289 range
